Mad Scientist
Standard gear ratio?
1984 Jimmy, 305 w/700r. What was the standard axle ratio in these?
![]() 86 1/2ton on tons! sbc/465/208/D60/14/35's 81 Postal....with 468 bbc 97 Merc Marq comuter 07 Suburban 02 Danger Ranger |
Re: Standard gear ratio?
RPO code on the sticker in glovebox should answer this, unless the axles have been re-geared or swapped. I can't remember where I saw this listings for the different codes.
74 K5 Blazer-built 350ci,Turbo 350, NP 205 8 lug Dana 44, GM Corp 14 bolt-4.56 gears, 37" Boggers 89 K5 Blazer-TBI 350, 700r4, NP 208 8 lug Dana 44, GM Corp 14 bolt-4.10 gears, 33" Toyo A/T Last edited by Plumbnutz; 12-03-2007 at 11:08 AM. |
74 K5 Blazer-built 350ci,Turbo 350, NP 205 8 lug Dana 44, GM Corp 14 bolt-4.56 gears, 37" Boggers 89 K5 Blazer-TBI 350, 700r4, NP 208 8 lug Dana 44, GM Corp 14 bolt-4.10 gears, 33" Toyo A/T |
Mad Scientist
Hey, thanks for the list! I've never heard of 3:21's and also noticed no 3:42's on there. I'm guessing I have 3:08's but not sure and not ready to pull the covers yet.
you dont have to pull the cover. simply raise both rear wheels off the ground turn them one full rotation and watch how many times the driveshaft turns. that is the ratio. if you mark the tire and driveshaft with white chalk it makes it easier.
