Old 12-02-2007, 06:50 PM   #1
shortbed70
shortbed70's Avatar
Another Z'd frame question.
Does anyone have a writeup on how to do this on a 65 model fram and still have all the factory mnts for rad fenders etc. I want to do this to my truck while I'm in the process of 5 lug swap. Pics are nice too. Does efabman have any of this on his vedeo?
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 12-03-2007, 03:08 PM   #2
ZBS 64
ZBS 64's Avatar
Re: Another Z'd frame question.
The better way to go is a porterbuilt dropmember
ZBS 64 is offline   Reply With Quote
Old 12-03-2007, 11:11 PM   #3
L0WRIDE
L0WRIDE's Avatar
i z'd my 65 but if i had the money i would buy a drop member from porterbuilt
49 CHEVROLET 1/2 TON, 52 CHEVROLET SEDAN
62 HARDTOP NOVA
65 CHEVROLET BB LWB FLEETSIDE
90 CHEVROLET EXTRA CAB
CHEVY ONLY - NZ Chapter
http://67-72chevytrucks.com/vboard/s...d.php?t=137984
L0WRIDE is offline   Reply With Quote
Old 12-04-2007, 10:25 AM   #4
mullit
mullit's Avatar
price seams to be the only issue with the drop member
mullit is offline   Reply With Quote
Old 12-04-2007, 03:14 PM   #5
shortbed70
shortbed70's Avatar
How much $?
Troy
Big Red Dog build
Old 12-06-2007, 11:27 PM   #6
Mkcustums
Mkcustums's Avatar
Originally Posted by shortbed70 View Post
How much $?
Last I heard it was $1,200
http://67-72chevytrucks.com/vboard/s...d.php?t=201898
"It is made to bolt into 63-87 Chevrolet Trucks, 2wd and those who are tired of their 4wd sitting too high. It uses a rack and pinion, designed to be used with tubular arms (Air Ride Tech.) but can be used with stock arms (slight modification to lower arm is needed), it allows the frame to set on the ground with a drop spindle and a 29 inch tall tire. Porterbuilt Street Rods is the manufacturer and they sell for a whopping $1200."
Mkcustums is offline   Reply With Quote
Old 12-07-2007, 11:38 AM   #7
WELD4DAYS
I'm thinking of "Zing" my 77 and was wondering if you can do this with the motor still in the truck? I can't afford a dropmember so I need to go this route.Thanks
WELD4DAYS is offline   Reply With Quote
Old 12-07-2007, 12:46 PM   #8
revn67
revn67's Avatar
i dont think id try it with the motor still in it....i would imagine it would be alittle more difficult to measure and keep the frame straight and level with the motor in the way...just my 2 cents though, and i believe the 1200 for the dropmember is just for the crossmember and a few little thing...you'll still need a steering rack, all the airbag needs, i think its around like 2500 all together to get your truck rolling
67 small windowed,shortbed,fleetside, sbc 327, th350,12 bolt :under the knife:
71 cab for sale in parts classifieds!
2004 black chevy 1500
"finish your beer, theres sober kids in india!"
revn67 is offline   Reply With Quote
Old 12-07-2007, 07:29 PM   #9
mullit
mullit's Avatar
Try $1400 just for the member $300 for a rack, $300 for the stearing linkage, $40 for the stearing linkage support bearing plus shipping. Now throw in you air suspension parts and drop spindles. and you still have to cut the frame for tirerod notches.
Old 12-07-2007, 07:33 PM   #10
XXL
Seņor Member
XXL's Avatar
Doing it "right" isn't always cheap. There's a very big difference between 'seat of the pants' and engineered products... and that engineering costs. While I'm not opposed to the time-tested z-method, it's not necessary given today's engineered products-- spindles, control arms, notched xmembers (or PB's Dropmember), etc.
XXL is offline   Reply With Quote
Old 12-07-2007, 07:17 PM   #11
Slmd92DIME
Slmd92DIME's Avatar
While trimming the botttom of the frame make sure you either box the frame or put box tubing in the top corner and weld it up.... just a thought
Slmd92DIME is offline   Reply With Quote
Old 12-07-2007, 07:19 PM   #12
Slmd92DIME
Slmd92DIME's Avatar
Instead of doing that.... you can lower your cab mounts an inch... That will be darn close to laying rockers.... Just another thought
Old 12-08-2007, 10:19 AM   #13
Slmd92DIME
Slmd92DIME's Avatar
yes it will still need a Z. The Z is what raises the front crossmember above the frame rails. the droppin of the cab mounts is what will get your rockers as low as the frame. You dont have to cut the frame under the cab.. Just lower the body mounts, cut the rivets out.. and move your holes down and inch and weld your old holes up.
Old 12-08-2007, 01:46 PM   #14
Slmd92DIME
Slmd92DIME's Avatar
If you lower the cab mounts an inch and you have a 4 inch Z at the firewall, you would want to lower your front frame horns 5 inches to accomidate for your dropped cab mounts. The fender and cab need to be on the same level...
I dropped my cab mounts, its easy.
I also made a new tranny crossmember to accomidate for the Z and also to get it above the frame rails. Pictures are in my build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=269019
Old 12-08-2007, 02:13 PM   #15
WELD4DAYS
Nice job Dime.I'm trying to figure out how much of a Z I need to do to get the controls arms off the ground.I want to run 22's.I'm not sure if I want to lower the mounts or trim the bottom of the frame.If I lower the mounts,then I need to lower the bed an inch also right?Thanks for the help
Old 12-08-2007, 02:23 PM   #16
Slmd92DIME
Slmd92DIME's Avatar
What is the tire height that you want with the 22s? I am sure a 4 inch Z would be fine. I also have a set of 3 inch drop spindles. Yes you wouldhave to lower the bed an inch also. Get some pics up of what your truck looks right now.
Old 12-08-2007, 02:46 PM   #17
WELD4DAYS
I will try to post some pics tonight when I get home.I'm trying to sell my project boat so I can go full speed on my truck.I'm not sure how tall the tire will be.I don't want something to low profile.I will be using drop spindles also.
Old 12-08-2007, 04:11 PM   #18
WELD4DAYS
Here is a couple.
http://i145.photobucket.com/albums/r...ing2007088.jpg
http://i145.photobucket.com/albums/r...ing2007087.jpg
http://i145.photobucket.com/albums/r...ing2007086.jpg
Old 12-08-2007, 04:25 PM   #19
Slmd92DIME
Slmd92DIME's Avatar
looks pretty solid... Nice T-HOE
Good Start
Old 12-08-2007, 04:42 PM   #20
WELD4DAYS
Thanks man.It's pretty solid.Runs like a champ.It needs all new bushings up front.It used to be red,but it sat out in the sun for about 5 years.It has electric windows and locks,and my 2002 Silverado has manual everything.Can't wait to tear into it.
Old 12-08-2007, 10:14 PM   #21
WELD4DAYS
Here is a couple more of my 77.
http://i145.photobucket.com/albums/r239/TCRUSH/021.jpg
http://i145.photobucket.com/albums/r239/TCRUSH/020.jpg
Old 12-08-2007, 10:23 PM   #22
Slmd92DIME
Slmd92DIME's Avatar
Looks good... what size drop is on your blue chevy?
Old 12-09-2007, 06:45 AM   #23
WELD4DAYS
The 02 has a 4/6 DJM kit on it.I would like to lower the back 1 more inch.Thanks
