12-04-2007, 09:19 PM | #1 |
Tailshaft length on a 67'
Hi every one, i have a 67 chevy longbed. Im planning on putting a turbo 350 in it instead of the 3speed manual. The question i have is im wondering what size tailshaft came stock on a 67 auto trans? Also if i put this tranny in will i need to do any lengthning or shortning of my driveshaft?
12-04-2007, 09:52 PM | #2 |
Re: Tailshaft length on a 67'
I have the same question so any answers are helpful
12-04-2007, 10:01 PM | #3 |
67-72 parts collector,…
Use a turbo 350 with the "short" tailshaft and it will be a bolt in. Driveshaft won't have to be cut and the 3-speed yoke will work in the turbo 350. Of course you'll have to remove the bellhousing crossmember, and install all the auto trans. related stuff. What are you using for a shifter? Steering column swap?
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-05-2007 at 06:46 PM. |
12-04-2007, 10:12 PM | #4 |
what length is the short tailshaft? My grandpa is a mechanic and he said the turbo 350 tailshaft came in 3 different lengths (he thought it was 4,7, and 9?). I think im going to put a floor shifter since it would be easier to hookup. Unless i can find a auto steering column with all the linkage for cheap. Do you know anyone selling a floor shifter?
12-04-2007, 11:26 PM | #5 |
Use the shortest one. I'm not sure of the length,... but it's what I always called a "shortshaft 350". OK,... I just Googled it. Heres the quote: (Three tail shaft housing lengths were available, 6 1/4", 9 1/4", and 12 1/4"). So it's the 6 1/4 " one. Here's the link: http://www.teufert.net/t350/t350.htm
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-04-2007 at 11:27 PM. |
12-05-2007, 11:34 AM | #6 |
Are you sure that the short shaft will bolt right up? I don't want to put the wrong length in and have to change it. thanks i appreciate your help
12-05-2007, 12:16 PM | #7 |
i dont think turbo 350 was available in 67 so the only surefire way to check for fit would be to measure
12-05-2007, 07:19 PM | #8 |
Check out this link:http://www.hotrodssuperstore.com/trandim.html or this one:http://www.tciauto.com/Products/TechInfo/trans_dims.asp.
12-05-2007, 09:30 PM | #9 |
Thanks for the help. I think the short shaft will work. I found a site earlier today that said the 67 came equipped with a powerglie, TH350, or 3 speed manual. I hope it works if not im gonna loose some moeny and time. Also where do i get a transmission cooler at? my raidator is from a 78' chevy i think it has spots for coolig lines to hook up.
12-05-2007, 12:15 PM | #10 |
I did this exact swap years agos to my old '69 LWB. I swapped in the auto steering column and trans. crossmember also. Don't go by my word. Get out the tape measure and measure from your "bellhousing-to-engine flange", back to the tip of the tailshaft. Then measure a shortshaft turbo 350. You need all the associated stuff like a trans cooler, dipstick, etc. It would be easier if you could find a donor truck and get everything. Hope I helped you.
12-05-2007, 09:44 PM | #11 |
Do you have all the other stuff? You know,... auto. trans. crossmember, dipstick, cooling lines, flexplate and bolts, and some kind of shifter. Also the old 3-speed crossmember is riveted to the frame, so that will have to be ground or torched off. Remote transmission coolers can be purchased at most any parts store.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-05-2007 at 09:45 PM. |
12-05-2007, 10:27 PM | #12 |
my grandpa probally has a dipstick and cooling lines lying around. Hes a mechanic so he has lots of part, Where to i get a different cross memeber from? I think im going to use a floor shifter but i have not found one yet(still looking)
12-05-2007, 10:38 PM | #13 |
Send a PM to Teeitup,... he always has lots of parts. You can also do a search in the parts section. You just can't POST in the for sale section unless you are a subscribing member. (But that's only $25 a year,... which is the best deal on the planet right now)
