Old 10-11-2002, 02:47 PM   #1
Burlinator
Just Another Crazy Canuck
Burlinator's Avatar
power for elec choke
will the old points distributor wire(yellow wire) supply enough power for and electric choke on a qjet?
I am running HEI and this wire is jsut hanging there taped off can I use it?
Thx, Burlinator
1985 454/465/205, 38.5x11-16BOGGERS
soon to be installed: 14bDETROIT,Edelbrock Performer cam,intake and valve springs,Comp roller tips,MSD HEI
Burlinator is offline   Reply With Quote
Old 10-11-2002, 04:07 PM   #2
ckhd
ckhd's Avatar
I'll bet it will make it function, more or less. The problem is that wire is only going to supply around 9 volts. Your choke is made and calibrated for 12.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 10-11-2002, 04:56 PM   #3
Fast68Chevy
Fast68Chevy's Avatar
eliminate the yellow wire, it ran from + at coil down to the R post on solenoid, and tape off the end of the white wire that also ran to + on the coil.
run you a new 14 guage wire from the batt terminal on HEi cap to the fuse panel wher eit says ign unfused(spade terminal), and run you an inine fuse around 15 or 20 amp, easycake
good luck
Fast68Chevy is offline   Reply With Quote
Old 10-11-2002, 05:41 PM   #4
neonlarry
neonlarry's Avatar
When I put the HEi on mine, it only had one yellow wire going to the coil that had 12 volts all the time (no white wire) I took the yellow wire off of the solenoid, the yellow wire that I took off of the coil still had 12 volts. I know it wasn't suppose to be like that, but?
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 10-11-2002, 09:49 PM   #5
Gordo
Smile
I used that wire but I went back into the harness and cut off the "resister" wire and replaced with a 16 ga automotive wire. That original "resister"wire will give you a 12V reading until you put a load on it then it drops.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
