Old 12-05-2007, 04:54 PM   #1
fastazhell
fastazhell's Avatar
options for power steering and power brakes?
Looking to upgrade my 71 c10 to power steering and power brakes. what are my options? for the power steering i am mainly worried about bracketry, i know all the components needed for the swap, just not sure where to get the brackets. I have a 350 with the short water pump and center bolt motor mounts. also the junk yards around here don't have much for 67-72 trucks. as for the power brakes, can I just add a power booster or do i need to swap out the master cylinder and the proportioning valve as well? any info and help is much appreciated.
thanks,
russ
71 LWB c10- needs more work than I have money!
ASE certified Ford Master Tech
fastazhell is offline   Reply With Quote
Old 12-06-2007, 06:24 PM   #2
Ace in the hole
Re: options for power steering and power brakes?
I thought you only need a proportioning valve for disc brakes. with drums you don't need it, is this correct? seems like I read that you can just add a power unit to the master cylinder for power drum brakes.
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 12-06-2007, 07:03 PM   #3
Sinister
Between Trucks...
Sinister's Avatar
I have a '69 with power drum brakes and it has a proportioning valve...
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 12-06-2007, 08:04 PM   #4
Ace in the hole
sure its a proportioning valve and not just a pass thru type of block?
Old 12-06-2007, 08:26 PM   #5
Sinister
Between Trucks...
Sinister's Avatar
Might be, but I'm fairly certain it is, I'll have to go out and look at it...
Beat it to fit,
Old 12-12-2007, 08:51 AM   #6
fastazhell
fastazhell's Avatar
yea my truck is a 71 and has disc up front and drum in the rear. I plan on adding the new stuff, just wasn't keen to spending 300 or so from Brothers and such for the whole kit. Thinking about it now though, for the booster, proper booster pushrod, master, prop valve and booster brackets, doesn't sound too bad for what you get.
thanks,
russ
Old 12-06-2007, 08:17 PM   #7
wibilly
wibilly's Avatar
71's had disk brakes, but not all were power asisted. i say buy it all new,if you build a truck from junk parts you get all done to find you have a junk truck. brakes are a good place to spend alittle extra. ps brackets can be found on the parts board
common sense isn't so common anymore
wibilly is offline   Reply With Quote
