12-06-2007, 05:10 PM | #1 |
External Fuel Cell
I received a 15gal. fuel cell for free, it would have to mounted in the bed. Was wondering what peoples thoughts are on fuel cells, what are the pros and cons. What is needed to make the conversion on a 64GMC SWBFS? Thanks for you opinions.
Mike
1964 GMC SWBFS 2005 Dodge Magnum RT |
12-06-2007, 05:17 PM | #2 |
Re: External Fuel Cell
You shouldn't use it and give it to me? haha, just messin.
You can make or buy some brackets to have it at the rear of the frame under the bed. Other than that you just need to run longer fuel lines to the cell. |
12-06-2007, 08:15 PM | #3 |
Cons are higher center of gravity with the fuel up high and difficulty in making the gauge sender work. Along with making your bed worthless.
Pro: If you tube out the wheelwells it would look sweet with a fuel cell. |
12-06-2007, 09:55 PM | #4 |
David, I have a fuel tank for you, has a few small pin holes. I hear those are great on gas mileage with the added O2. LOL!
12-06-2007, 10:43 PM | #5 |
con.. It is only 15 gals which means alot of gas stops... I know I had one..
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
12-07-2007, 12:22 AM | #6 |
yes, i do
damn. wish i could get my hands on one. since my truck is sitting on a mid 70's 2wd blazer frame, the conversion on mine would be alot easier. i hate the fact that my motor is eating brown gas
ERROR 404....... SNAPPY COMEBACK NOT FOUND _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
12-07-2007, 08:42 PM | #7 |
Rust Buster
60rat.....newer blazer and suburban tanks were mounted between the rails in the back. Just a thought. BTW never had any luck for you on the grille, sorry. Jerry
12-08-2007, 02:35 AM | #8 |
yes, i do
hey thanks jerry. if i got one i would try to mount it between the rails since my 60 is sitting on a mid 70's 2wd blazer frame. odd i know, but i didn't start this project of mine. i kinda figured that you wouldn't find one. so i'm thinking of making one
ERROR 404....... SNAPPY COMEBACK NOT FOUND _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 Last edited by 60ratrod; 12-10-2007 at 09:47 AM. |
12-13-2007, 03:53 PM | #9 |
Resistance is Futile
Heres mine........20 gal Summit special!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
