Old 12-09-2007, 08:19 PM   #1
David Flores
David Flores's Avatar
Sound deadener
What are some good sound deadener mats? Is b-quiet or Sound Destroyer any good?
If anyone has put sound deadener in your truck, how many sq. feet did it take?
thanks.
66 c10 swbfs
My Build.
David Flores is offline   Reply With Quote
Old 12-09-2007, 08:36 PM   #2
Rokcrln
Rokcrln's Avatar
Re: Sound deadener
I have Dana mat in my 70 Low Buck and it worked great so far. I bought 50 sq ft and had enough to do the back of the cab wall, between the head liner and roof (stock CST headliner type) and on the floor up to were it starts to turn up the fire wall. I will need another 50 to finish with two layers on the fire wall, kick panels and some inside the doors.
I will be spraying Lizard Skin in a customers blazer/truck but I have no personal feeed back on how it works yet.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 12-09-2007, 09:00 PM   #3
85gmcguy
Plays with trucks
85gmcguy's Avatar
Re: Sound deadener
I can't remember where this link was posted, but several folks there swore by it as being cheaper and better than "Lizard Skin". I can't vouch for that, but I'm sure planning on trying it when I get ready
http://www.hytechsales.com/prodsc.html
Gary
My Dad's Old Truck
1985
85gmcguy is offline   Reply With Quote
Old 12-09-2007, 09:37 PM   #4
David Flores
Re: Sound deadener
I remember that! I couldn't think of the name of it though.
I may order some to test out.
66 c10 swbfs
My Build.
Old 12-09-2007, 08:56 PM   #5
Slmd92DIME
Slmd92DIME's Avatar
Re: Sound deadener
I have heard of some people use some stuff from Lowes.. I dont know how good it works but I might just try it out... they called it garage door deatener or something along that lines... Its a lot cheaper than Dynamat
Slmd92DIME is offline   Reply With Quote
Old 12-21-2007, 05:58 AM   #6
Chevy Fleetside
Chevy Fleetside's Avatar
Re: Sound deadener
It is probably the same stuff. It is just packaged differntly. I am sure it is used on the metal garage doors so the metal will not rattle when in use, which is what this stuff dose.. It keep the metal from making a tinning sounds when you hit bumps. The cab on my truck was pretty quiet without any kind of matting. Most of the noise came from all the holes in the firewall which are not sealed up.. I do have a full headliner in the truck which I don't like but it seemed to help out.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 12-10-2007, 03:16 AM   #7
19GMC63
19GMC63's Avatar
Re: Sound deadener
has anyone used fatmat?
The price seems to be right.
http://cgi.ebay.com/ebaymotors/100-F...QQcmdZViewItem
19GMC63 is offline   Reply With Quote
Old 12-20-2007, 08:04 PM   #8
sixtyfour
Zombie Killer
sixtyfour's Avatar
Re: Sound deadener
I went the Dynamat way, Easy to work with but kind of expensive! Well worth it IMO.
sixtyfour is offline   Reply With Quote
Old 12-21-2007, 04:01 AM   #9
Slmd92DIME
Slmd92DIME's Avatar
Re: Sound deadener
What was the total cost to do your cab in Dyna mat?
Old 12-21-2007, 04:21 AM   #10
sixtyfour
Zombie Killer
sixtyfour's Avatar
Re: Sound deadener
I'm guessing it cost me around $350. to $400. worth of Dynamat.
Old 12-21-2007, 05:51 AM   #11
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Re: Sound deadener
I used a product called Hushmat. Apparently it is one of, or the only sound dampening material used as original equipment by the car manufacturers... Don't know if this claim is true but the stuff is awesome... Peel and stick application and is guaranteed to stick. Cost me about the same as sixty four. Used about 160 square feet. Unbelievable, I know but I covered everything, even put it inside the doors. My truck is loud and I can barely hear it run with the windows rolled up tight. Well worth the money IMO.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 12-21-2007, 05:54 AM   #12
badriand
badriand's Avatar
Re: Sound deadener
Ok this is where the cheap person chimes in. I used peal and seal from Lowes , it's like for roofs kinda a asphalt type on one side and real thin alum type on the other side. Just as the title peal and seal. Took me 2 rolls to do my 66 helped alot like 15$ each roll.
http://www.lowes.com/lowes/lkn?actio...625&lpage=none
badriand is offline   Reply With Quote
Old 12-21-2007, 10:32 AM   #13
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Re: Sound deadener
The one thing to consider with the cheaper products is the density of the material. It may or may not make any difference to you but the more expensive products are likely a lot more dense and, as a result, with deaden sound and vibration more effectively. A 55 square foot box of the Hushmat product I used weighed about 45 lbs... It's actually very surprising when you go to lifth this "little" box of material and realize it weighs nearly 50 lbs.
1978 Chevy C/10 SWB
1970 Pontiac Lemans
Old 12-22-2007, 04:26 AM   #14
badriand
badriand's Avatar
Re: Sound deadener
I was acutally pretty suprised with the peal and seal. It's pretty thick in relation to dynomat and i have turn downs before my rear axle and it killed alot of the cab noise. With 2 kids i have to cut corners sometimes on cost for my own toys.
Old 12-22-2007, 06:19 AM   #15
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Re: Sound deadener
Firstly, let me say I'm not trying to bash any products or suggest anyone not use them, I'm just posting some information from my experience so that others can make an informed decision.
"Thickness" may not necessarily be a good thing. That is where the density of the material comes in. I imagine that one square foot of the Hushmat or Dynomat product weighs as much, or probably more, than the same area of the Peal and Seal material. The thing about Hushmat is that it is only 1/8" thick which can make a difference when installing it behind door panels, headliners, upholstery or anything else. The thin layer of material is going to provide as much or more dampening as other products without creating a thick layer behind whatever is going on top of it.
1978 Chevy C/10 SWB
1970 Pontiac Lemans
Old 12-22-2007, 06:42 AM   #16
mbgmike
Re: Sound deadener
Even though we sell Hushmat Brand. On my vehicles I use a material just as good as DynoMat or Hushmat from a roofing supply company. Why buy it just cause it has fancy advertising? It comes in a roll 18" or so wide with foil on it and works the same. No one sees the name on it. Its just good value for me. you can do two trucks for less then the cost of one using the name brands. Of course I never did any accoustic tests on it but with my old ears I can't tell any.
Mike
mbgmike is offline   Reply With Quote
Old 12-24-2007, 09:07 PM   #17
blackedoutharley
Re: Sound deadener
Several years ago I did the sound deadening thing to my '65. Due to the exhaust exiting in front of the rear tires it placed the mufflers under the floorboards which created a noise level in the cab that was very unacceptable.
First I moved the mufflers to under the bed and ran the exhaust out the back. Huge improvement but I wanted more with the new stereo system install. Dynamat, while great stuff, was just too expensive for me so I found an alternative that I found to be not only acceptable but very inexpensive.
It is nothing more than the plastic bubble wrap used in packaging but this stuff has an aluminum skin on both sides. I got it at the local OSH store (should be available at most hardware stores) and I think I did the whole cab for under $40. This included the entire floor, back side of cab, fuel tank, outer skins of doors, door panels and filled the cab corners. It wasnt so thick as to create problems with seat or amplifier installation and provided the needed sound reduction to make the stereo system play at its optimum clarity (given the limitations of an all metal cab interior). This was complimented by the installation of a complete carpet kit that reaches all the way to below the fuel tank.
Just another alternative that worked for me and would certainly work for others trying to gain these benefits on a meager budget.
blackedoutharley is offline   Reply With Quote
Old 12-25-2007, 10:56 AM   #18
ElkyRacer
Re: Sound deadener
Ive been researching and hearing SO MUCH about the Lizzard Skin product, that when I came across this, I was stoked! Read through the thread in the link, its worth your time.
http://www.hotrodders.com/forum/alte...in-103610.html
I love cheaper ways of doing what others sell for lots of money!
ElkyRacer is offline   Reply With Quote
Old 12-25-2007, 04:03 PM   #19
David Flores
Re: Sound deadener
I just ordered a gallon of it. Not sure when I'll get it due to the holidays.
I'll let you know the results when I spray it.
66 c10 swbfs
My Build.
