Old 12-11-2007, 11:02 AM   #1
TeamRinaldi
TeamRinaldi's Avatar
Heavier Suspension Conversion?
Hey all. I've got a '85 "big 10" that I'm looking to do some cross country traveling with. I'm building her up to have plenty of power, but I'm looking to pull a 40' trailer (about 9K lbs). So, what all needs to be done? Can I put on the heavier spring pack and roll, or do I have to convert to the 14 bolt rear end and 6/8 lug? Many have told me to get another truck, I haven't slapped anyone as yet. I love my truck! As always, thanks in advance for the advice.
TeamRinaldi is offline   Reply With Quote
Old 12-11-2007, 11:31 AM   #2
Pyrotechnic
Pyrotechnic's Avatar
Re: Heavier Suspension Conversion?
Since you have a Big 10, that means you have 3/4 ton springs already. An 8 lug 14 bolt rear will bolt right in to give you a true 3/4 ton or you can step up to 1 ton spring packs that will bolt right in for a 1 ton rating.
In front, you can swap rotors and spindles to get 8 lugs. I forget if the front calipers are different or not. You could also put 1 ton springs in the front if you want as well.
With all this, you will basically have a single rear wheel 1 ton truck.
Pyrotechnic is offline   Reply With Quote
Old 12-11-2007, 01:08 PM   #3
TeamRinaldi
Cool, that's what I was hoping. Here's another question, with the rearend swap can I put in a limited slip or locker? I don't see whynot, just figured I'd ask.
Old 12-11-2007, 02:19 PM   #4
Pyrotechnic
Yes you can do whatever you want to the rear end.
Old 12-11-2007, 07:50 PM   #5
Morgsie
Arn't the 1/2 ton and 3/4ton frames different? As in, 3/4 ton uses thicker gauge steel and more braces?
Morgsie is offline   Reply With Quote
Old 12-11-2007, 08:54 PM   #6
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
the 1/2 and 3/4 are the same the 1 ton with the dual wheels and perhaps the single wheel ( cant say for sure about single wheel) are larger frames
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
