Old 12-12-2007, 02:42 PM   #1
Dads 68 GMC
Dads 68 GMC's Avatar
T-case to frame please help
I took a mounting bracket off a `69 blazer today and bolted it to my frame,now the bolts that go in the right side of the T-Case will not go in.I took the upper transmission mounts out & they almost line up. the mounts seem too thick,they are 1 1/8in.thick I called Carquest they only show one from `68 to `81.pn#31-2107 which is what I bought. Maybe i have to drill holes in my frame? I would appreciate any input,Thanks Philip
Dads 68 GMC is offline   Reply With Quote
Old 12-12-2007, 03:48 PM   #2
Blazer1970
Blazer1970's Avatar
Re: T-case to frame please help
Do you have the correct factory crossmember for the TH350/NP205 combo?
Blazer1970 is offline   Reply With Quote
Old 12-12-2007, 04:33 PM   #3
Yukon Jack
Yukon Jack's Avatar
The side mounting bracket you have from the 69 K5 may be for a Dana 20 transfer case instead of an NP205. Can't guarantee they are different, but I know the crossmember is different for a Dana 20 compared to the NP205 so likely the side bracket is different too.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 12-12-2007, 04:45 PM   #4
Jtrux
I'm a poor spectator
Jtrux's Avatar
Yep, what he said. Machine some spacers for it and run it.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 12-12-2007, 06:06 PM   #5
Dads 68 GMC
Smile Re: T-case to frame please help
thanx for the help guys, I think i need a different cross member.This truck had a v-6 4 speed,rockwell t-case from factory. When i put the v-8 cross member in i moved it ahead 2 in. & the trans. mount lined up so i thought i had it made until i got this side bracket maybe it is different also. I do some hunting for new parts tomorrow. THIS SIGHT IS GREAT LOTS OF AWSOME PEOPLE,Philip:
Old 12-13-2007, 05:39 AM   #6
Blazer1970
Blazer1970's Avatar
Your transfer case might also hit the floor pan if you try to use the crossmember that you have.
Old 12-13-2007, 07:33 AM   #7
jaros44sr
jaros44sr's Avatar
Maybe it's me, but is that crossmember upside down, can't really see, don't have my glaases on... J.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-13-2007, 07:43 AM   #8
CUSTOM/10
CUSTOM/10's Avatar
If that crossmember was from a 221 then that's your problem. There's a 1 in difference in height between the 221 & the 205 crossmembers. You need to get a crossmember from a truck ( 69-72 )that had a np205 t-case, standard or auto dosen't matter there both the same. I'm not sure about the torque mount that may also be different.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 12-14-2007, 05:04 AM   #9
pumpkin
pumpkin's Avatar
Ya, the crossmember looks upsidedown to me also.
pumpkin is offline   Reply With Quote
Old 12-14-2007, 04:50 PM   #10
Dads 68 GMC
I got a crossmember today for a 205t-case, it is one inche deeper than the original.thankyou to all of you that helped me get out of this bind,and no its not upside down,that would really put it waaaaaaaaaaaaaaaaaaay high.
Old 12-15-2007, 12:24 AM   #11
jaros44sr
jaros44sr's Avatar
OK, glad I was wrong
SAFETY FIRST
AS usual, off topic
Jim
Old 12-15-2007, 05:31 AM   #12
Yukon Jack
Yukon Jack's Avatar
Any chance you can get some comparison pics, always nice to have pics to show differences.
Old 12-13-2007, 10:24 AM   #13
Yukon Jack
Yukon Jack's Avatar
I should have added, I used 1" spacers to lower my Dana 20 transfer case crossmember to fit my NP205. Otherwise the NP205 was hitting the floor like mentioned above in relation to the Rockwell T221 crossmember.
