Old 12-13-2007, 12:38 PM   #1
Thunderace1997
What are you guys using to cut the body on your trucks?
I have a cut off tool and that works fine but I was wondering have any of you had experience with an air or electric sheer or nibbler?
Is a sheer or nibbler good enough for someone that does body work every once in a while or should I just continue using the cut off tool.
Thunderace1997 is offline   Reply With Quote
Old 12-13-2007, 12:47 PM   #2
cdowns
cdowns's Avatar
Re: What are you guys using to cut the body on your trucks?
it really depends what you're cutting// i'd be lost without my cutoff wheel another highuse tool is my jigsaw(paid $20 for it about 30years ago and still cuts with great precision) roughwork i use an air saw and sawzall
Old 12-13-2007, 01:23 PM   #3
67ChevyRedneck
67ChevyRedneck's Avatar
The only thing I'm capable of cutting straight lines with is a cut-off wheel
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-13-2007, 01:54 PM   #4
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Love the nibbler (air) but keep in mind they use allot high CFM's. I also do an awful lot with my cutoff wheel and like cdowns said the jig saw is great also.
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 12-13-2007, 05:26 PM   #5
BCOWANWHEELS
try a metabo cut off grinder.
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 12-13-2007, 02:16 PM   #6
Frizzle Fry
Frizzle Fry's Avatar
Cut-off wheel on 4.5" angle grinder gets used most in my garage. Sawzall and 1/2 handled hacksaw are needed for some cuts that the cut-off wheel can't reach.
I would like to try a nibbler.
I used an 8" cut-off wheel on a circle saw once to cut through the inner and outer bedside panels in one slice (for a long/short conversion).
Frizzle Fry is offline   Reply With Quote
Old 12-14-2007, 02:08 AM   #7
67_C-30
I have a radical idea!
67_C-30's Avatar
I use a cut-off wheel on 4.5" angle grinder for big stuff, and 2" cut-off wheel on a small pneumatic die grinder for the little stuff. I also have a portaband and a sawzall, but I don't use them that often with body work. If its something in a junkyard I use the torch sometimes, but I cut the the piece extra large to keep warpage away from the piece I need.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 12-14-2007, 03:01 PM   #8
Thunderace1997
I appreciate the replys. So has anyone on here ever used an air/electric sheer or air/electric nibbler on the body sheet metal? If so was it succesful???
Old 12-14-2007, 03:44 PM   #9
67_C-30
67_C-30's Avatar
I used them when I took body shop in high school, and they both work great, but I've never seen a need to run out and buy them. I bought a stud welder recently because the one we had in body shop worked great for pulling out dents w/o drilling holes. I don't see a real need for the sheer/nibbler unless you just want them.
My trucks
Old 12-13-2007, 02:24 PM   #10
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
I use the sawzall a lot.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 12-13-2007, 03:26 PM   #11
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
4.5" cutoff wheel on an angle grinder is my weapon of choice for sheet metal. When I'm feeling particularly adventurous (aka-crazy) and want to do some hardcore "dismantling"- like chopping a frame in half, I'll bust out the recip.saw and get after it. When I shortened my long bed....I bought a 7-1/4" cutoff blade for my worm-drive circ.saw and cut through both inner and outer bed panels in one pass. Lemme tell ya'....you ain't seen sparks till you fire up one of them bad boys! I've heard about carbide and diamond cable "chains" for chainsaws that can cut through pert near anything....haven't seen one though, but it would kick some serious a$$.
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
Old 12-13-2007, 03:29 PM   #12
caja_larga
Are you guys shorting the bed sides to do a conversion? got pics?
caja_larga is offline   Reply With Quote
Old 12-15-2007, 07:11 AM   #13
Frizzle Fry
One I started but never finished:
Old 12-13-2007, 04:07 PM   #14
Cut-off wheel, jig saw, and good ole American broken hack saw blades.
Old 12-13-2007, 04:10 PM   #15
BB70c10
BB70c10
BB70c10's Avatar
i just started chopping the bed on mine this past weekend.i used a sawzall to cut inside and out at the same time.the cuts looked good to me using the sawzall, but i still have to line everything back up for welding.it's my first time cutting,so im sure i'll find out why everybody uses cutoff wheels.if you're planning on cutting your bed,i have a thread under projects and build that might help you avoid some of the mistakes i made(just starting it).
MY BUILD: http://67-72chevytrucks.com/vboard/s...d.php?t=268981
heres some pics:
BB70c10 is offline   Reply With Quote
Old 12-13-2007, 04:18 PM   #16
72lb4x4
Monster electric die grinder w/ cutoff wheel
Sawzall
Circular saw w/ 7" cutoff blade for the yough stuff
Air powered die grinder
72lb4x4 is offline   Reply With Quote
Old 12-13-2007, 07:13 PM   #17
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
caja larga, there is a write up in the builds section that detail this very well.It is by member Rockcrawlin Spelling is different tho.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-14-2007, 03:44 PM   #18
Rust Buster
Rust Buster's Avatar
I bought a Bosch electric shear a few months ago. The thing is huge and powerful, cuts through 16 gauge like it was paper. It's is great for cutting flat sheets of replacement sheet metal. Downside is that it is real heavy and I doubt it would be good on curved metal like body panels, but I haven't really tried that. I'd worry that it would contort it. For body panels I just prefer a cut-off wheel. Doesn't distort the metal at all.
Just my 2 cents.
Maj USAF
71 K5 Blazer CST
72 K20 HT383 NV4500 Mass-Flo EFI
71 K10 LWB
52 Dodge Power Wagon
67 Dodge WM300 Power Wagon
48 Dodge WDX Power Wagon
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=239487
Rust Buster is offline   Reply With Quote
Old 12-14-2007, 04:01 PM   #19
Thunderace1997
I've used sheers in metal class over 10 years ago but never electric/air. I know that manuel sheers did distort the metal somewhat.
Does a nibbler distort the metal???
Old 12-14-2007, 04:04 PM   #20
67_C-30
67_C-30's Avatar
In my experience it does wrinkle the edges a little. I remember using a hammer and dolly to work some parts out. The upside is that there is no heat and it won't cause widespread warpage. With that being said when I fabricated my rear fender flares for my dually (see my build thread below), I did it all with a cut off wheel and had no warpage. Welding the mounts was a another story!
My trucks
Old 12-15-2007, 12:53 AM   #21
jaros44sr
jaros44sr's Avatar
Depends on what your cutting. If I have to cut a relatively flat pc. I use my Milw. electric nibblers, I can control it better with the variable speed. I can see the line better. The nibblers keep both edges flat, but won't cut much of a contour. That's where the 4 1/2" angle grinder comes in, used to use air cutoff, but got tired of it stalling... J.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
