12-13-2007, 05:38 PM | #1 |
so easy a caveman can do it...
A couple of questions before the back half of the truck is put together
Is there some sort of o ring, gasket, or something that goes in between the drain plug and the housing? There is about a 1/4"...maybe a little less of threads showing.
I was thinking about using some thredloc on all of the bolts. Are there some that it wouldn't be a good idea for? Is blue thredloc the one to use? I have a re-print of the factory manual and it has all of the torque specs for all of the bolts. Should I just make a list of all of the specs, torque to that and then re-check after 100 miles? I believe the bolts at the front of the trailing arms call for 280 ft/lbs. I was talking to my neighbor who is more of a mechanic than me and he told me I didn't need a torque wrench that went that high and that he would set his impact to "kill" and that would be fine. I dunno about that...maybe I'm being too anal about things, but I've taken my time grinding, sanding, painting, buying quality parts and don't want things to go to crap cause I slammed it all together. Is there anything else I'm forgetting? |
12-13-2007, 06:03 PM | #2 |
Re: A couple of questions before the back half of the truck is put together
from the factory that fill plug had a plastic tag on it thats the reason for the gap// believe the tag had gearoil specs
12-14-2007, 04:21 AM | #3 |
morning bump for some good advice
12-15-2007, 04:52 PM | #4 |
o.k. one more bump and I'll let it die. Any info on the drainplug? Anything at all ? lol <----when is this appropriate to use in a thread?
12-15-2007, 10:06 PM | #5 |
Picture of the red tag dif. tag.
esll.
Tomorrow is for doing today's stuff. ************************************* This truck has just the right amount of energy for me! Author: Warren Lake .... (member) |
