12-14-2007, 01:09 PM | #1 |
Question about tranny's
Ok, newb question. Looking to put an automatic tranny in my 64 GMC which has a 3spd manual on the floor. What stock trannys are out there that could handle atleast 400hp, and will it bolt to my current 327? Will upgrade motor in the future that will potential, "cross fingers" make around 400hp. Just looking for simple answers as I know there are many variables out there. Thanks in advance.
Mike
1964 GMC SWBFS 2005 Dodge Magnum RT |
12-14-2007, 01:45 PM | #2 | |
Re: Question about tranny's
I would think a 700R4. It's used in a lot of street rods. |
12-14-2007, 02:14 PM | #3 |
Why does it taste purple?
TH350
TH400 2 speed Powerglide |
12-14-2007, 02:30 PM | #4 |
I have a 700r4 behind my 327.
12-14-2007, 02:58 PM | #5 |
12-14-2007, 03:25 PM | #6 |
Registered thread killer
I like the 700R4. It has a pretty aggressive 1st gear, so if you are hauling a load or pulling a trailer, it can easily get you rolling, and the overdrive is easy on the gas $$$. Just my two.
!966 stepside, 350 SB, ZZ-4 roller, Crane roller rockers, 0.030 flat tops, airgap intake, 750 Holley, stainless steel headers, edelbrock SDT mufflers, Mark 8 elec fan, 700R-4, column shift |
12-14-2007, 03:53 PM | #7 |
What type of vehicles have those installed stock, maybe I can pick one up at the junkyard. What would be the going price for something like that? Thanks for the info guys.
1964 GMC SWBFS 2005 Dodge Magnum RT Last edited by mtburg71; 12-14-2007 at 03:54 PM. |
12-19-2007, 05:52 PM | #8 |
Mine has a 200-4R. The gear ratios are closer so you don't have as big a drop between 1st and 2nd. Also the overdrive is a slightly better ratio. I run mine without a lock-up TC so setting it up is simple. As for 400hp, it can be built to hold it with a few aftermarket parts. If you aren't running slicks you will probably not hook up good enough to break it. I've towed a yard of concrete with my truck and that is pretty hard on the trans as well.
