Old 12-16-2007, 03:54 AM   #1
70cst
70cst's Avatar
Question on rebuild...new wiring or not?
Ok truck lovers...as I was sitting here continuing my Truck 101 education...the thought came to me? When my truck is bing restored this winter....should I have all new wiring installed or keep the original. I know there are about a dozen manufactures out there...is one of them really a head above the rest as far as quality and ease of installation? Thanks in advance!
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 12-16-2007, 04:09 AM   #2
ChevyC102007
ChevyC102007's Avatar
Re: Question on rebuild...new wiring or not?
IMHO I would replace the wiring in your pickup. The original wires are at least 38-40 years old and may have alot of barespots yet uncovered that could cause problems later down the road. As stated in another post youll be kicking yourself for not replacing the wiring after the truck is back together (and its probably gonna be TONS easier to replace the wiring with everything apart.)
As for wiring kits Ive heard alot of good things about Painless wiring kits for ease of installation. Everything is marked as to were it goes and comes with easy to follow instructions and a new fuse box that uses the modern blade style fuses. The down side is $$$ cost, The Summit racing catalog lists the full 18 circuit GM truck wiring kit for $319 dollars plus tax and shipping (if applicable) Im sure though someone else on the boards can point you towards either a board vendor or other source for wiring harness kits.
Just my .02 cents
"When you were born, you cried and the world rejoiced.
Live your life so that when you die, the world cries and you rejoice."
[Cherokee saying]
2001 Dodge Ram Sport 1500 4x4. (old ride)
1987 GMC V1500 Sierra Classic ("new" ride)
ChevyC102007 is offline   Reply With Quote
Old 12-16-2007, 04:13 AM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
40 year old wire with brittle cracking insulation.Has probably had stereo,trailer and other accessories wired in at some time.Along with hardened brittle Grommets.Yeah, I think that's the way to go!
"NOT!" I always figure if it's worth doing it's worth doing right.There are some things to consider though.What style of truck are you building?A fairly stock truck can use an OEM style harness while a full on custom will probably require a few extra curcuits and may need to be hidden as much as possible.Budget should also play a role.OEM style harnesses are available from most of the BB vendors as are the aftermarket style.You will need to have a plan so that you can let them know what accessories you will be running.
To answer your original question,yes replace the harness.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-16-2007, 04:31 AM   #4
70cst
70cst's Avatar
As far as what type of truck...it will be close to stock w/o a lot of mods. I have added pertronics....otherwise it will be close to the way "electrically" that it left the factory. It now has 5 lug verses 6 lug but not many other changes have taken place. I look at my budget and all the work translates into $$$ but sounds like this would be a well spent investment. Thanks for you replies thus far.
Old 12-16-2007, 04:51 AM   #5
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
I would recommend replacing the harness as also suggested by the previous posts. There are allot of manufactures out there selling great harnesses and those selling not so great harnesses. A good OEM replica harness is the M&H.
Vendors such as GMC Paul sells this harness.
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 12-16-2007, 05:00 AM   #6
hdflstf
hdflstf's Avatar
Replace if you have a mind to. There are so many potential gremlins and intermittent problems lurking in the old wiring. Cracked or broken wire strands. Cracked, worn, brittle, missing insulation.
hdflstf is offline   Reply With Quote
Old 12-16-2007, 05:03 AM   #7
cdowns
cdowns's Avatar
i'd first clean(gojo works great) and inspect the original harness and see exactly what you've got if in fact the wire is rotted and cracking replacr it but if its not then i see no reason to spend hundreds for a replacement if all it needs is a little attention i've reconditioned meny wiring harness in the 50-60 year old range that are still working fine
Old 12-16-2007, 07:01 AM   #8
TotalChevy1
TotalChevy1's Avatar
i would recommend inspecting it first, I just did that I was actual very suprises at the condition of the wiring. 90% looked new, especailly the stuff that was still wrapped. I cleaned and re-wrapped. Did have a couple areas were they had been modified but that is fixable. Even the engine compartment was 100% sound.
1972 c-20, 350/350, dana 60 w/456 gears(no Posi)
TotalChevy1 is offline   Reply With Quote
Old 12-16-2007, 06:54 AM   #9
orgalmeister
$300 or so is cheap insurance to keep your truck from burning to the ground. Ask my neighbor who almost did that to his '55 shoebox.
'56 truck (the never ending project)
'06 Z/71 loaded (daily driver)
'07 Mercedes-Benz C-Class (wife's driver)
Gone: 72 SB, 67 CST, 57 BBW, 47 Panel streetrod,
orgalmeister is offline   Reply With Quote
Old 12-16-2007, 10:49 AM   #10
BigSky71
LAIDOUT
BigSky71's Avatar
Do it! I didn't look forward to installing my painless 18 circuit wiring kit, but once I got into it, I was surprised how easy it was.
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 12-16-2007, 11:34 AM   #11
David Flores
David Flores's Avatar
Anyone hear anything about EZ Wiring harnesses? Good? Bad?
66 c10 swbfs
My Build.
David Flores is offline   Reply With Quote
Old 12-16-2007, 11:38 AM   #12
70cst
70cst's Avatar
Thanks guys...this is good info.
Old 12-16-2007, 12:09 PM   #13
chip46wis
My 2 cents----I really thought my wires were in good shape---a good friend that works at the world famous Muscle Car Restoration here in town made a good point----for under $200.00 get new wires so all that hard work doesnt go up in SMOKE.
I bought a EZ2wire for around $200.00 NO it is not installed as I am not at that point,and yes I am lucky if I reach a snag I have several of the top Rodders-mechanics as good friends.
chip46wis is offline   Reply With Quote
Old 12-16-2007, 01:08 PM   #14
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I've only owned 4 of these trucks... and they were all worked hard most, if not all there lives. Every single one, I inspected and repaired any problems, which were far and few between.
The aftermarket is making billions of dollars off the FEAR of electrical repairs. It's real easy stuff, and odds are, you don't need to rewire the whole truck.
Old 12-16-2007, 04:06 PM   #15
kxnomore
kxnomore's Avatar
If you do replace the harness (which was a no brainer for me as my trucks had rat's nest wiring) look at the Harnesses sold in the Classic Parts Catalog made by American Auto Wire. I bought one from them that was an absolutely perfect match. It went in so nice and had ALL the right plastic gutters, wire ends, colors, heat proof wrapping, etc.
I also installed a "painless" kit in another truck that needed all sorts of fittings and grommets installed and such. And it didn't have the wire ties in the right places, and basically took way more time and effort. But it did cost about half...
kxnomore is offline   Reply With Quote
