Trailing arm lowering block
I have a 69 stepside----trailing arm rear can I use rear lowering blocks on this?----It just doesnt seem like they would work----if so where can I get a set and how big can I go?---3in 4in?----confused here.
OR is it easier and safer to just go with lowering springs? Thanx |
its all about the +6 inches
Re: Trailing arm lowering block
moving to the 67-72 truck page
NP---thank you for the up.
My buddy and I are working on lowereing blocks for these. I would not recommend more than about three inches. Pm me with what you need. I may be able to help. They are very easy to do and much cheaper than springs.
1947 International KB-1 1957 Chevy Bel-Air riding low 1962 swb fleetside 2002 Chevrolet Silverado 7-inch lift on 35 Daily driver 2016 Chevy Tahoe Better halves ride |
Yes you can use lowering blocks on your truck. You will need the blocks and longer U bolts.
I would strongly not recommend anything over 2 inches. |
For safety's sake, don't use a block that would let any part of the suspension hang below the edge of the wheel. This allows a solid metal suspension part to drag the ground in the event of a flat tire. Steering and braking both suffer. So, maximum block size is somewhat determined by wheel diameter....with-in reason. You start to get a leverage issue, much like lift blocks on 4x4s, when you get too thick...I wouldn't go more than 2"
BlahBlahBlah
First off I agree totally with what LONGHAIR said. I do find it amusing though whenever this subject comes up, (and it does come up fairly often) everyone posts how dangerous it can be to let anything get below the scrubline. But no one says jack when a truck is posted where the whole thing can drag on the ground, they just go off on how great it is.
![]() Last edited by CG; 12-18-2007 at 05:07 PM. |
Excellent points well taken---THANK YOU-I will be running a 285 170 15 radial I think this should clear any problems---
senior member
i ran a 2.5: inch block for about 2 years with out any huge problems but i did take into account the things these guys are telling you about the safety
69 GMC bagged |
Yes you can and I do. I have 2' blocks in the back. They are also easy to make if you have the time.
esll... ![]() I'm running 295 R50X15 in the rear. I used to run 305's but BFG/TA does not make these anymore. No problems with tire rubbing.
Tomorrow is for doing today's stuff. ![]() ************************************* This truck has just the right amount of energy for me! ![]() Author: Warren Lake .... (member) |
Watch out for your cornhole !
![]() Join Date: Jun 2003
It's a catastrophic success.
![]() Join Date: Jan 2003
Nice I just book marked that page!
With a 2'' lowering block, would shims be needed to maintain proper pinion angle?
#15 |
![]() Join Date: Jan 2011
Shound still be ok. .. but 1-2deg would take care of it if needed. I usually run 1 deg per inch of drop. IF you have a two piece driveshaft it might be a little less of an issue. (less jumprope / harmonic vibe vs. the longer one piece. ) Just my experience..
