05-03-2002, 01:13 PM | #1 |
can i use the rear end and spindels from a nova?
i can pick up a 72' nova can i use any of the parts to make my 67 5 bolt?
83,67,60,and53 chevy pickups |
05-03-2002, 01:48 PM | #2 |
I doubt it. I think the Nova (1 of my favorite cars) isn't as wide and uses smaller 5 lug bolt pattern. Novas were leaf spring rearends, Trucks were coil or leaf. I had asked a few weeks earlier about a using the posi unit from a 68 chevelle that I wanted to put in my truck and was told that everything was smaller......
------------------ Woody '69 Custom-10 Deluxe Short Fleetside,Factory 350cid/TH400,A/C,PS,PB,Carpet Coming soon 700R4, 350 Crate Engine, Pwr Disks... |
05-03-2002, 02:02 PM | #3 |
Does the Nova have disc brakes. If so, they are in high demand for 67-69 Camaro owners to do disc brake conversions. I have seen the the set-up go for $250 and up on e-bay. If you can get the Nova cheap enough and it is trashed you can make some parting it out.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB Second Owner 70 C-10 Second Owner 93 GMC C1500 Third Owner 99 C2500 Crew Cab Short Bed |
05-03-2002, 07:23 PM | #4 |
no you cannot, truck spindles are no where near same as truck ones, forget the idea and go find a 71-87 truck for parts'
rear axles only will work form 64-72 if you have coils and arms in rear, if you have leaves then you can use anything 64-87 if you move shock mount on one side and use the 73-up leaf plates and u bolts ------------------ Randy- Lincoln, IL randy@ccaonline.com 2177353230 *many GM parts bought, traded, or sold -am parting out: '81 Cutlass Supreme Brougham current fleet: -71 C-10 350/CH465/3.07- basketcase -84 Z28 5.0L/700R4/3.73 daily driver -84 Firebird/SE 2.8L/T-5/3.73/engine bad -82 purple Trans Am, project #2 *Paint is overrated* © RSS Enterprises 2000 |
