12-18-2007, 02:44 PM | #1 |
How do I separate an 1157 bulb?
I know sounds like a weird question, but I'd to know how to separate the glass from the base... I'm going to build my own led taillights and I need the base so I can use the existing sockets...
Thanks in advance! donovan
78 C10 LWB Super Cheyenne |
12-18-2007, 03:03 PM | #2 |
Re: How do I separate an 1157 bulb?
Hammer?
12-18-2007, 03:24 PM | #3 |
I am pretty sure you can buy a base with two leads coming out of it, if you don't want to make your own.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
12-18-2007, 05:53 PM | #4 |
its all about the +6 inches
12-18-2007, 03:28 PM | #5 |
u can heat the glue up that holds it to the base and it (SHOULD) come right off
12-18-2007, 03:59 PM | #6 |
BlahBlahBlah
Mine always seperate themselfs when Im trying to replace em.
12-18-2007, 04:05 PM | #7 |
Overdrive club
1971 c-10 1951 3100 chevy 1970 chevy c-30 Sold! |
12-18-2007, 04:31 PM | #8 |
They get pretty darn hot when in use so I don't think heat is the answer, unless you plan to "blow" some new glass globes
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
12-18-2007, 05:38 PM | #9 |
it works on a house light bulb dont ask how i know this
12-18-2007, 05:59 PM | #10 |
I've sprayed a product called Corrosion Block in the sockets before. It usually makes the bulb come apart as well.. not intended.
70 C10 long fleet, 355/200 4r, 6 lug disc conversion, 3" drop 70 gmc changed to 67/8 chevy, 454 with voodoo cam, th400, all 74 running gear.. in progress |
12-18-2007, 06:09 PM | #11 |
i bought a set of l.e.d. 1157 bulbs. they were only $10 for 2. been in my truck for two years...
12-18-2007, 08:01 PM | #12 |
i would buy an 1157 led already to install
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan |
12-19-2007, 12:54 AM | #13 |
those LED bulbs completely suck compaired to an LED panel. I would NEVER use those for tail lights. They don't put out enough light to be safe, nor to be DOT certified.
12-19-2007, 03:39 AM | #14 |
Well after seeing the led panel that some other board members have created I wanted a set. And since I have some experience with electronics I made the decision to make my own. I seen how their pigtail was wired up and thought that there may be a way to separate the glass from the base without damaging the base... I guess the hammer method would work, I'll just need to be careful to not damage the base...
Thanks. PS. Has anyone thought of doing an led panel for the dome light? Hadn't seen any postings regarding that idea.
12-19-2007, 08:35 AM | #15 |
Got to disagree with you on this one Longhorn. Have you checked the newer styles that are out? I have the 1157 bayonet LEDs on mine and are way bright and have 30 LEDs in each one. Paid $17 for the pair and no problems. Ask 70c10 about them......He was also impressed. They may not be as bright as the "higher priced spread" ones, but do light up the rear of the truck to my liking, day or night.
1997 GMC Sierra Ext 1965 Mustang |
12-19-2007, 01:00 PM | #16 |
eh, they dont completely suck for me, seeing its hard to stuff a l.e.d. panel in an aftermarket motorcycle directional...
12-19-2007, 04:27 AM | #17 |
I miss this truck.
http://superbrightleds.com/led_prods.htm
Has the 1157's with up to 30 LED's seems like they ought to be bright enough. Also have the dome lights pre-made. Also sells the base with wiring pigtails, I believe. Poke around a little, I'd say they have anything you'd ever want in an LED product.
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
