Motor mount help
I'm putting a power streering pump on my truck and need to convert from the front yoke type motor mount to side/frame mounts. I'd like to do this without pulling the engine. I've seen weld in "L" shaped motor mounts on hot rods that look like what I need. Does anybody know if this can be done and who sells the mounts?? Thanks.
Re: Motor mount help
Has anyone used the tublat crossmember that Rez sells to go to frame mounted mounts?
Resistance is Futile
Read your post.........you mite try looking at the thread with "big block clearance" as a title.......these guys posted all types of pics.
you can get mounts @ CPP, POL, and a bunch of other places.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
Professional Beer Tester
If you are going to stay with the old ram's horn exaust manifolds, you should be able to use 63-72 brackets and mounts. You can either drill the holes and bolt them in or weld them in if you don't want to pull the engine. Six or V8 mounts should work all the same, except for the RH mount for a 292 six. Hope that helps.
60-66 Nut
60 Ford F100 Custom Cab 61 Apache Short Fleetside 64 C10 Short Stepside 65 C80 409 V8 5spd(X-Firetruck) 83 GMC 350 Olds Diesel 85 GMC Short Bed 86 GMC Short Bed 90 GMC R3500 Crew Cab 92 GMC 1500 |
After searching around I decided to try the Rez tubular crossmember. After I get it installed I'll take some pictures and post them if anyone is interested. Thanks for your thoughts.
Fuelpump, can I get some pics of your motor mount from the bottom? Thanks, 62 short step.
The current one. Thanks.
I bought the V8 crossmember from REZ but it just didn't work. We ended up cutting the mounting ears off of it and mounting them to the truck's crossmember. I guess its as good as any approach.
