Old 12-20-2007, 03:28 PM   #1
stomper
Junior Member
stomper's Avatar
Rust repair on my K5 - pix
I heard it was slow around here so I thought I'd share some pic of Livrat's repair work on my K5. Something to look at.... We were hoping the A pilars would be rust free but alass... no... How does the mud get down in there!? Gonna cut those off and see what's behind....
"I was patina when patina wasn't cool."
1973 Cheyenne SWB Sunset Gold / Frost White / Saddle
stomper is offline   Reply With Quote
Old 12-20-2007, 04:00 PM   #2
71jimmy
71jimmy's Avatar
Re: Rust repair on my K5 - pix
That doesn't look too bad. Mine was a bit worse. I'm just finishing up the passenger side. Have you given any thought on how to fix the area I've circled in your pic below? I don't think anyone makes a patch for this. Any ideas?
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 12-21-2007, 03:50 AM   #3
jb4short
Damn Yankee
jb4short's Avatar
Is that panel in there almost a mirror or the lower rear pillar?
jb4short is offline   Reply With Quote
Old 12-21-2007, 03:59 AM   #4
jaros44sr
jaros44sr's Avatar
Yes, are you thinking to take a rt side and turn it into a left?
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-21-2007, 04:01 AM   #5
jb4short
Damn Yankee
jb4short's Avatar
I'm thinking it might work to have a panel to start with
Old 12-20-2007, 04:40 PM   #6
David Johnson
David Johnson's Avatar
I thought GMCPauls offered those.
http://www.gmcpauls.com/Patch_Panels.htm
David Johnson is offline   Reply With Quote
Old 12-20-2007, 05:14 PM   #7
stomper
Junior Member
stomper's Avatar
I have the bolt in pieces from GMC Paul's. Livrat, the guy doing the work for me, was in on the development of the bolt-ins. He says there are no patch panels for the area circled - have to fabricate that. Unless someone else can chime in...
Old 12-20-2007, 06:28 PM   #8
jaros44sr
jaros44sr's Avatar
Could you pls. post up some more pics of the area in question, i've never seen one that complete. I have to fab up most of that area and as much information as i can get would be very helpful. That whole area looks real nice, are you just going to get rid of the rust and rehang a rocker?
SAFETY FIRST
AS usual, off topic
Jim
Old 12-20-2007, 07:56 PM   #9
71jimmy
71jimmy's Avatar
It's starting to look like my only option is trying to fab that area. Doesn't look like an easy piece to fab up, unless your into doing that kind of stuff and have the proper tooling. I would think that quite a few folks could use that patch. Any chance our friend Livrat could produce several of those for us?
Old 12-21-2007, 03:22 AM   #10
jaros44sr
jaros44sr's Avatar
Just noticed the cutoff tool, looks like it has great accessibility into tight spots. Gotta get one of those.
Great work, nice to see original painted floors with the insulation. Looks like you caught it just in time
SAFETY FIRST
AS usual, off topic
Jim
Old 12-21-2007, 04:14 AM   #11
Huck
Huck's Avatar
The "B" pillar on Blazers are unique to that vehicle. It is not accessable from the outside so that getting any kind of rustproofing into the cavity is nearly impossible. To make matters worse, it captures moisture and then just holds it in there to rust over time. I have a colorado blazer and have seen many from California, New Mexico, Utah, Arizona etc with rust in the lower portion of the B pillar and lower leading edge of the rear quarters. Unfortunately you can't just remove or unbolt a section to have total access!! About the best you can do is exactly as pictured--cut out lower section, fab replacement pieces and then just POR15 the hell out of it before reassembly. BUt you really need to get up into the entire B pillar--no easy task. Huck
Huck is offline   Reply With Quote
Old 12-21-2007, 01:28 PM   #12
pound41
Most of my B pillar is intact as are the rocker boxes. But most of the floor is gone. Which I am replacing. In looking at mine today I don't think it would be that hard to make. since most of my floorpan and rockers are cut out and the end cap on rocker boxes are out. I have a pretty good view.
The piece circled in the pic follows the body lines. Start with a repo patch of the section in front of rear wheel. Measure the 1-2inch piece that backs the same area as the patch panel. Cut slits top/bottom and maybe cut one in the middle. Hard part of countouring that done. Bend flat. You now have the section that now backs the b pillar it knotches around something and then comes down. The curved part at the bottom matches the lower curve of the body, You have a pattern. The bend that has the bolt holes would require some work. But I think what i came up with in looking at it rather quickly is a place you could start
pound41 is offline   Reply With Quote
Old 12-21-2007, 04:04 PM   #13
stomper
Junior Member
stomper's Avatar
Here's a better shot of both dr and pas side B pillar in circled area. These are already off and will be replaced. Pound41, I can't follow ya - pix?
After cutting the A pillar ends off and looking, I decided to just treat the rust, replace what we've cut off so far and call it good. Maybe I'm dumb, but I like saving as much of the original metal as possible, even if it has some imperfections. The kick panels for example have a little corrosion started at the bottom seam, but you still can't stab an awl thru anywhere. If I replace it all, I might as well have started with a rust bucket.
Kudos to Livrat for being patient and doing just what I asked.
Man, what a shock to see the front sheet metal off! I wanted to start scrubbing the truck with soap and water!
Old 12-21-2007, 05:41 PM   #14
jaros44sr
jaros44sr's Avatar
That's perfect, I see what I needed to see. Thanks for taking the time I apreciate it...
Your right about only replacing what has to be dun. J
SAFETY FIRST
AS usual, off topic
Jim
Old 01-06-2008, 03:59 PM   #15
stomper
Junior Member
stomper's Avatar
It's going back together. Thanks Livrat!
Old 01-06-2008, 04:06 PM   #16
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Very nice work
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 01-06-2008, 04:19 PM   #17
jaros44sr
jaros44sr's Avatar
Thanks for the pics, they speak volumns. Nice work!!! Appreciate you taking the time... J.
BTW, gotta get some of those clamps
SAFETY FIRST
AS usual, off topic
Jim
Old 01-06-2008, 09:47 PM   #18
71jimmy
71jimmy's Avatar
Very nice job on the B pillar patch. Any chance you could give a detailed run down on how you did it?
Any chance you made some extras to sell?
Old 03-03-2008, 07:07 AM   #19
Big Chief
I took the plunge and cut off my old rockers and bottom quarters. I also need this B pillar. Any advice on replacing this piece? I'm guessing no one is making these yet?
Big Chief is offline   Reply With Quote
Old 03-03-2008, 07:12 AM   #20
jaros44sr
jaros44sr's Avatar
As far as I can tell, you have to make it. Can you start a thread and post up pics. of where you are at in your disassembly? J.
SAFETY FIRST
AS usual, off topic
Jim
Old 03-03-2008, 08:17 AM   #21
Gillnetter
Gillnetter's Avatar
Going trough the same repairs.Time consuming but well worth it.
1972 Blazer CST Dark Olive, am/fm, tilt, tow hooks, tach dash
1972 SWB C-10 Highlander Blue/White
1972 Canadian 2wd Jimmy light olive
1970 SWB 4x4 4 speed 307
Gillnetter is offline   Reply With Quote
Old 07-12-2014, 11:52 AM   #22
briank
Gillnetter, pm sent
briank is offline   Reply With Quote
Old 07-14-2014, 12:18 PM   #23
cleszkie
cleszkie's Avatar
That lower B-pilar patch is (or was available). I bought a set from a guy on this board that was making them (about 3 years ago). Nice heavy gauge metal and a good fit. I will try and dig up the source.
cleszkie is offline   Reply With Quote
Old 07-15-2014, 09:05 PM   #24
Livrat
Member #1049
Livrat's Avatar
Correct, They were not available in 2007 when I did the work Stomper's Blazer but thanks to Wes at Classicheartbeat they are available now.
http://www.classicheartbeat.com/cata...ar%20Patch.htm
Livrat is offline   Reply With Quote
Old 07-20-2014, 10:44 AM   #25
Chulisohombre
Chulisohombre's Avatar
Nice work fixing that rust. I had to build mine up Myself to as there wasn't anything prefabbed to use. I took out the rear seam and made the rocker and quarter panel one piece by welding a patch between them and the b pillar. I never liked the rear seam being there so I deleted it when I repaired that spot. Not perfect but got the rust holes out of it.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
