Old 12-22-2007, 05:34 PM   #1
Andy4639
Old member
Andy4639's Avatar
Got a little more done...
Went and picked up the new speedo cable and installed it.
Then I started on the door adjustment, took me awhile but I got the door to shut and lock both. It took some shimming but now it shut's without slamming it.
Once I got the door to work correctly I did the driver's side door panel. I have to either dye the armrest or buy new ones. I haven't decided what I'm going to do yet. Here are the door panels my wife & I did tonight. Hope to have the passenger side done by tomorrow night.
Did some work under the hood also. When I installed the water jug for the windsheild wiper I covered up the old speedo hole so I had to move it to put the cable back like it should be. Had to put the jug out on the fender.
I had the red loom stuff so I redid it also.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-22-2007, 06:57 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Got a little more done...
Door panel looks great.... The wire looms always seem to make things look cleaner under the hood...
Keep up the good work!!
I'm puttin' a tuned port in my '70.
LockDoc
Leon
Old 12-22-2007, 07:11 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Truck looks good, but the wire loom distracts from the motor.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-25-2007, 06:40 AM   #4
c10crazy
Like a Rock!
c10crazy's Avatar
I agree!. I would paint the engine bay and swap out all those red looms for black ones. You have alot of custom items on your truck. What holds the panels on???
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 12-25-2007, 06:49 AM   #5
Andy4639
Old member
Andy4639's Avatar
c10crazy
I'm not sure if the wire loom will stay or not???
The door panels ar being held by the plastic Christmas Tree's for a lack of better tirm.
Plastic Fasteners
Panel Fasteners
Christmas Tree® and Pine Tree Clips®
Old 12-25-2007, 06:55 AM   #6
c10crazy
Like a Rock!
c10crazy's Avatar
Cool, where did you find the pleated vinyl?
69 LWB
Old 12-25-2007, 07:16 AM   #7
Andy4639
Old member
Andy4639's Avatar
I bought the pleather for the dash 60" long. The door panel material was three yards worth. It was already to go just cut and glue it on.
Here is the company's name.
Contour South WC
603 S. Old Piedmont Hwy
Greenville SC 29606
(864) 422 0207
http://www.manta.com/coms2/dnbcompany_0hbvqz
Old 12-22-2007, 08:26 PM   #8
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Great job on the door panels... The truck is coming along very nicely. My suggestion for your arm rests would be to paint them. I did my dash pad with SEM products. As long as you prep the items using their vinyl wash and don't touch it with your fingers before the paint is applied, it sticks like glue. I can take my fingernail to the dash pad and the color will not come off... Very durable if applied properly.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 12-22-2007, 08:35 PM   #9
CG
BlahBlahBlah
I really like your door panels. Simple, but very cool. I have been undecided how I was going to mount my window switches. After seeing yours I can see I was over thinking it. I'm probably going to copy you.
Old 12-23-2007, 09:30 AM   #10
Andy4639
Old member
Andy4639's Avatar
Thanks guy's, no problem with copying the idea. I did too! Here is the passenger side done. I learned a few things while doing the driver's side so I went back and redid it also. Looks a lot better.
N2TRUX,
I thought it did to but I wanted to change out the black and add some color under the hood.
Old 12-25-2007, 05:59 AM   #11
Andy4639
Old member
Andy4639's Avatar
OK I'm satisfied with them but was wondering what they would look like with the chrome trim around the edge of the panels...what do you all think?
Something like this if I can find it big enough to slip over the material.
Old 12-25-2007, 06:27 AM   #12
67_C-30
I have a radical idea!
67_C-30's Avatar
What's that filter box out of, a 90's Cadillac? If so I have one I'm thinking of using on something also. Mine has a "hat" that fits over the TBI that also fits a Q-jet ot Holley carb.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 12-25-2007, 06:35 AM   #13
Andy4639
Old member
Andy4639's Avatar
If I remeber right it's like a 90 Seville caddy. I pluged the factory open with sheet metal and drilled a 4" hole in the bottom of it. Used to coupler's and a 90 from Lowes. Drilled another 4" hole where the old regulator was mounted.
