tranny cross member help
Here are some pics of my problem. What could I use to take up the space? It's 2 inches that I need. I guess a piece of 2 inch square tubing would work? Anyone have some other ideas?
Re: tranny cross member help
The square tubing is a good idea. Or maybe weld a piece or angle iron inside frame to bolt crossmember. Then theres always spacers like some chevy trucks used.
The angle iron is a good idea. Then I wouldn't have to have 2 1/2 to 3 inch bolts going all the way down. I guess the easiest would be the spacers.
Cantankerous Geezer
From an engineering standpoint, angle bolted to the frame will be best. If you use tubing, I would recommend using short bolts, bolting the tube to the frame and the tube to the crossmember. Long bolts through the tube become a major problem with shear loads. Meaning that if you bump into something too hard you will probably break a bolt.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
#5 | |
I added some pics. Turned out well. Last edited by 62 short step; 12-24-2007 at 11:52 AM. |
Looks like a problem to me. With the C channel is sitting atop the angle bracket, there is a hollow under the bolts. Bascially, it can't be tightened, it will just collapse. Maybe it will feel tight when you put it together, but with use it will flex and settle, and always be coming loose.
Some spacers under the bolts to take up the space might be good enought. I'd rather see the angle brackets shortened to fit up inside the C channel, and raised appropriately so it is metal-to-metal at the bolts. |
Yea, its not ideal. But I have some spacers I'm going to put up in that void. Thanks for your concern, any help is appreciated!!
resident wrencher
glad you went the angle way cuz i was gonna saystick a 2x4 in and call it done that would have been better that what they did to mine they used a stop sign post as the cross member but it works good
![]() Join Date: Apr 2007
looking good there Jermey
Is that an NP208?
If it is there are two adapters, a 'tall' and a 'short'.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs. 84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80 68 GMC C20 Parts? Truck And a few cars ![]() |
