Chevy One
Air Ride for the Rear?
Working on my 67 2WD, LWB with coils
![]() ARNOTT AIR SPRINGS 100 MM STRAIGHT SLEEVE AIR SPRINGS SERIES, PAIR 14" MAXIMUM EXTENSION! THESE ARE CUSTOM AIR SPRINGS DESIGNED FOR VARIOUS APPLICATIONS. PART# 10014VR. SPECIFICATIONS: Ride height 10" Max inflated diameter 5.7" Minimum compressed height 6" Full extension 14" 1/4" NPT air inlet 1500 lbs. @ 100 PSI. I don't know if the 1500 lb will be enough for towing? Any advice would be great. CO ![]()
Chevy One ![]() 67 1/2 Two-on-the-Floor 67 Nova 2Dr Sedan 03 Monte Carlo I'M NOT OLD, JUST A CLASSIC!!! |
Re: Air Ride for the Rear?
call clint up at kp components.. kpcomponents.com tell him what you are after and he'll figure everything up and set you up..866-575-4657
Trailing arm trucks should use a double-convoluted bag if it is being used in the factory coil-spring location.
Firestone 2500#/2600# & Slam RE 6's/7's can be used & they bolt-in w/minimal fab work.
Between Trucks...
Any details or links for this?
Beat it to fit, Paint it to match... ![]() |
There's a good installation 'how-to' in the FAQ's section from board member 'MrShelly'. It contains excellent pics which explain much more that typed words.....
I've purchased bags from both AirRide & Suicide Doors.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-25-2007 at 12:02 PM. |
#6 | |
Boosted Member
There didn't appear to be a bracket of any sort?? Thanks, Jeff
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
