12-26-2007, 08:23 AM | #1 |
UK Wildcat Fan!
350 won't start-where should I look?
it's a 78 350 w/ the coil built into the cap (is that an HEI?).
The engine will NOT start. replaced the inline fuel filter in the 2 barrell carb-tested it and there is plenty of gas coming out (pumped it manually and observed it squirting in). Air-tryed placing a towel over the carb, closing the butterfly shut, partially open, no indication it wants to start. finally, replaced cap,rotor and checked spark at end of a plug-it's there, but not strong. not sure how strong it should be, but there is spark. will go back and replace plugs to see if that helps. how about the spark-how much spark do you NEED to start the engine? gas and starting fluid in the carb made no impact on it starting and I hooked up the jumper cables to get it turning more quickly-still no dice. help! I've exhausted all my ideas except for a weak coil-would like to know it's bad before buying another (is there a test?) |
12-26-2007, 04:08 PM | #2 |
UK Wildcat Fan!
Re: 350 won't start-where should I look?
problem fixed. Turned out to be the plugs-as soon as a new set was installed, the engine started on the first shot. they were black and 'fouled'
12-26-2007, 06:00 PM | #3 |
Wishin' I had more money!
You probably flooded it, and in the time it took you to replace plugs, it cleared the cylinders, and started. New plugs will definately help, but I doubt that it wouldn't start because all the plugs were that bad. If they were you got some serious problems there!
And yes, coil in cap is HEI |
12-27-2007, 02:06 PM | #4 |
UK Wildcat Fan!
I would have thought the same thing about coming back later after flooding it. The problem was recurring-I had three different mornings of trying to start it, all with no 'luck'. The plugs looked to be gapped a little more closely then speced
