12-28-2007, 08:40 AM | #1 |
Kung Fu Master
Lift Kit opinions
Looking at a 4" kit for the 72. Rough Country seems to be the cheapest. Who would recommend them or others? A few others I am aware of are: Tuff Country, Pro Comp, Skyjacker. I plan on an all spring lift also.
What else will I need?
72 GMC SuperCustom 4x4 1972 Chevrolet Cheyenne Super 4x4 |
12-28-2007, 09:48 AM | #2 |
Re: Lift Kit opinions
I think the best balance of price and quality is Tuff Country bought directly from www.suspensionconnection.com .
12-28-2007, 09:49 AM | #3 |
After my 1 year ordeal with Rough Country I'd recommend them to none..
I'd go with Skyjacker.They may be expensive but you get what you pay for.. Typically in an all spring lift included is the shocks,springs (4),u bolts,bushings,brake line relocater.You may or may not need a raised steering arm.Some lift kits come with them but ususually not unless you get a 6" lift or higher.Usually you get the option of a adding a steering stabilizer,raised steering arm,and upgraded shocks too.Those cost extra of course..Keep in mind that with a lift comes bigger tires most of the time and the bigger tires may be too big for the gear ratio (If it's geared high,Which is typical if you have a 1/2 ton) and slow you down.Also keep in mind with bigger tires,more axle wear can occur.Those are just some things to think about.With a 34 or smaller you shouldn't have to worry much though.. Last edited by 1969k10stepside; 12-28-2007 at 09:53 AM. |
12-28-2007, 10:09 AM | #4 |
Kung Fu Master
My plan is to go with 33's. Right now, 3.73 gears. I need to completely go through both front and rear diffs. Hope to get them done by Spring.
Now, one more question. Would anyone recommend buying oem rear springs and using blocks? I need rear springs regardless.
12-28-2007, 10:55 AM | #5 |
I wouldn't buy stock then add blocks... Just get all new springs and be done with it.... or buy stock and do a shackle flip (ORD website)
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
12-28-2007, 02:14 PM | #6 |
Gross is right... buy the taller springs don't hassle with the blocks. I just got done doing the same thing that you are doing now, 33's, 4" lift, 3.73 gears. it will look awesome.
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project. 1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver. |
12-28-2007, 02:30 PM | #7 |
Kung Fu Master
Thanks for the info. Anyone else have any more opinions on the kits?
12-28-2007, 04:35 PM | #8 |
I have Rough Country 4", was cheap and has worked well so far, rides a little stiff but not bad. I would get the steering correction though, my steering wheel is a little off. They have good customer service, I lost my front axle harware kit before I installed the lift and they send me a new one the next day for free.
12-28-2007, 04:47 PM | #9 |
I had a rough country once. Rough country means rides rougher than any truck in the county stay away. I like the tuff country front springs and the ord shackle reversal for the rear. If money wasn't an issue I would go with deaver's in the front and the ord shackle in the rear.
12-28-2007, 05:06 PM | #10 |
Kung Fu Master
LOL I wondered about that. They are inexpensive, and they have free shipping right now. Just thought I'd inquire, but I will go with another brand. What is deavers? Never heard of them. I'll have to do a search.
12-28-2007, 04:58 PM | #11 |
Mudder used BDS springs I think... 4" with 33's does look pretty good.
I am doing narrow 33's with no lift. But I have HD springs in the front and added a leaf in the rear...
12-29-2007, 03:14 AM | #12 |
Have you checked Suspension Connection?You`ll be amazed at the total cost of an all spring lift including everything you need.You get what you pay for for less.Their quality is every bit as good,if not better,than Skyjacker and they are in Utah.The shipping would be alot cheaper for where you are,too.
12-29-2007, 04:40 AM | #13 |
For deaver springs talk to these guys. Like I said they are not cheap but you will get a truck that will ride and work like no other. WWW. dixonbrosracing.com and do a search.
12-29-2007, 06:05 AM | #14 |
Kung Fu Master
Yep, the deaver springs are spendy. I also checked out the suspension connection and they have a decent kit. Looks like I'll go that route. They have an option of a "heavy duty" spring package, or their EZ-ride springs. Guess'n the EZ-ride would be the way to go. The actual kit mfg. is Tuff Country. Won't be hauling anything. And it won't be for mudd'n, we don't get enough rain around here. But snow.....that might be fun.
12-29-2007, 06:50 AM | #15 |
Good deal you will like the tuff country lift. For a moderate 4x4 that should be a good set-up. Post up some pics as you get started and keep us up to date on your project.
12-29-2007, 08:53 AM | #16 |
Kung Fu Master
I kind of lucked out finding this thing. I'm technically the 3rd owner. It had been sitting in a dark quanset for the last 20 years. There are a few small dents, but this was used as a farm truck for a while. Of course the tailgate was toast. I'm guessing most people backed up by feel or sound back then. LOL Odometer shows 53,500. Can't say for sure this is original miles, but judging from the interior, it could be. I have a few pics of it still in the quanset the first time I saw it, I need to find and I'll attach.
72 GMC SuperCustom 4x4 1972 Chevrolet Cheyenne Super 4x4 Last edited by WestButteTruck; 12-29-2007 at 02:28 PM. |
12-29-2007, 03:30 PM | #17 | |
itsweird every tailgate around here is same with huge dent and i have a 4" superlift and it great i ran 33's no lift for awhile and i still have 33's an it looks good |
12-29-2007, 04:12 PM | #18 |
nice find on that truck... grille guard too.
I know you haven't mentioned it... but don't mess with body lifts.... I have used one on an S-10 and it came out ok but lots of little adjustments/mods for very little ground clearance gain...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 12-29-2007 at 04:14 PM. |
12-30-2007, 03:37 AM | #19 |
Nice find on that SuperCustom.Prolly is original miles.Are those 16" rims that were on it?Yeah,Suspension Connection and TuffCountry are one in the same.Just one is marketing,the other manufacturing.But,tha`s why the price is so good.I used the 6" EZ-Ride system on my Highlander.It had busted up leafs and had been pretty beat.I haul a bit with it and it handles that fine.I think it rides great,too.I see a rough spot I can`t avoid and expect to get jarred and it just sucks it up.I used the 4" EZ-Rides on my`91 Suburban and it always is loaded with Carpwntry tools.I also tow a trailer from time to time.I`ve had it pretty loaded and the springs handle it fine.On that one I got Rancho 9000RSXs that are adjustable.I use the softest setting unless I`m totally loaded or towing.I used to haul three other guys to work,too.I`m very pleased with these springs.
01-02-2008, 08:57 PM | #20 |
Beauty truck eh. West Butte huh. May check in the Dillon area if looking for parts. There is a tiny wrecking yard behind the Town Pump. Looks like all farm machinery, but the old guy has gold hidden in the bushes. Found a nice 67 front clip in there when I lived in Dillon. As far as the lift kit, stay away from rough country, not very helpful customer service in my experience. Plus you need a kidney belt to ride in your truck after the install.
1969 4x4 Nothing beats a good rock drill and some dynamite |
01-03-2008, 02:52 AM | #21 |
i called rough country and they said ya we got a kit we'll send it right out to you i waited a week and i called back and they were on back order for front springs and i was pissed they never called to say they weren't sending my lift i just called and got a superlift which is great but i wanna get a shackle flip instead of the block
01-03-2008, 06:40 AM | #22 |
I don't care for the 6" BDS. It's too stiff. The pro Comps aren't helping.(shocks). I like Tuff Country's ride with the rancho 9000's.
01-06-2008, 03:25 PM | #23 |
hay guys all springs are going to need a break in but superlifts are superstiff so dont waste money on them
nickle and dime |
