Old 12-28-2007, 06:43 PM   #1
Pogwa
(Might Purchase) **2001 Chevy S-10** (Any Feedback?)
http://phoenix.craigslist.org/car/483123141.html
"Extremely clean 4 cyl automatic. 105K miles (60K on new engine) Runs great. Great vehicle for teens,2nd car, or work truck."
Good price?
He said that I can feel free to make him an offer.
He said there were regular oil changes made, nothing major ever done besides the engine swap.
Me and my dad are going to go check it out.
What you guys think?
Pogwa is offline   Reply With Quote
Old 12-29-2007, 02:42 PM   #2
odie82
odie82's Avatar
Re: (Might Purchase) **2001 Chevy S-10** (Any Feedback?)
I recently bought one also, 1998 2wd 4 banger 5 speed, for my work truck. my full size used to much gas, the s10 gets about 22-24mpg with 130,000 on the clock.
off topic:
I was going to by a different s10, went to go look at it with money in hand, test drove and told the guy I would think about it but I wanted it right there, he said there was nothing ever wrong with it, long story short came home did a car fax report and the truck was in a really bad accident, called the guy back and then he told me the truth after I comfronded him
I will never by another car/truck with out one.
1982 chevy C-10, blue 2wd shortbox
17x9 cragar ss rims, 350V8-th400
2003 suzuki gsxr 1000-hit 175mph!!!
yeah it's fast-no you can't ride it
odie82 is offline   Reply With Quote
Old 12-29-2007, 03:55 PM   #3
Pogwa
off topic:
Regarding Carfax - Is it free ?
- Micah !
Old 12-29-2007, 04:20 PM   #4
kszygc
Nope, not free, but WELL WORTH IT. $30. www.carfax.com
kszygc is offline   Reply With Quote
Old 12-29-2007, 05:39 PM   #5
Pogwa
Ok, sweeeet, thanks a lot for the input!
Also, the guy that I might buy this truck from said that there is a problem with the AC :
-It "Blows", but isn't as cold as it used to be.
What could that mean?
Could that be costy to repair in the worst case scenario?
- Micah !
Old 12-30-2007, 04:54 AM   #6
kszygc
It could mean a vicious bill, or it could be as cheap as a can of refrigerant and a servicing system. There are some cans of refrigerant that have the servicing nozzle on the can. I don't recommend them because you can't tell before you put it in if the system is low or not. What you would need is to measure the high side pressure side and the low pressure side and see if the compressor is functional. If the compressor has had a catastrophic failure and the pressure on both sides is roughly the same, then you have to change the compressor, drier/accumulator, the condenser if it's a parallel system, and then purge the lines and evaporator. If the compressor is working ok and it's cooling a little bit, just not like normal it could easily be just short a can and you're in there. Oddly enough, I just did this 3 months ago to my father-in-laws 2000 GMC Sonoma. It ended up costing $650 or so just in parts from the local parts chain.
BTW, the engine/tranny combination was just fine for an around town truck, even for highway commuting as long as the terrain is relatively flat. You don't need a powerhouse of an engine just to get around.
Old 12-30-2007, 03:22 AM   #7
I have never driven one of the 4-banger/automatic S-10s, but I had a 97 S10-extended cab 4 banger/5 speed and it was a great commute vehicle. No power, but it is all flat around here and it got good mileage and I had a big "trunk" to haul things for the house.
I am not sure how powerful or how much that automatic would suck out of that little 2.2 though.
Old 12-30-2007, 03:59 AM   #8
72freak
Rottenwood Garage Member
72freak's Avatar
105K miles (60K on new engine)...........says it all for me!!!!!
And yes......5 speed would be the ONLY way to even think about buying one....
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 12-31-2007, 02:33 PM   #9
speed
Junior Member
speed's Avatar
I had a 99 with the 2.2/auto tranny. It was gutless but I never had a problem with it other than the cat convertor went bad. Had 75K on it when i traded it off.
Used it for pulling a snowmobile or utility trailer and a work truck.
As for the A/C not working like it should most likely it needs some freon added to the system, but could be as serious as a leak somewhere in the system. Def have a AC shop check it out first.
Personally I think the price is a little high for a standard cab, closer to 2k-$2500 but also depends on how popular these trucks are in your area.
Jeff J
86 El Camino
81 Monte Carlo
81 Regal
04 Colorado
speed is offline   Reply With Quote
Old 01-02-2008, 06:15 AM   #10
RANDYC
clay
I have a 98 4.3v6, 182,000+ miles. I purchased from a retired guy at 50,000miles, Alot of small repairs, rear end, water pump, alternator, radiator, ball joints, head gasket, fuel pump, injectors to name some, plus normal maintanence, brakes, calipers, wires 1 set plugs, 3 batteries, lights door, hinges filter many many oil and filter changes (mobil 1) etc...
RANDYC is offline   Reply With Quote
