Old 12-30-2007, 03:23 PM   #1
64shortc10
64shortc10's Avatar
layin frame?
Ok how low can you go? Can someone show me how low on stock trailing arms, Kp notch, and a lowering block, and bags(stock location or not)Will it lay frame on 20's? Someone show me their truck on this combo! What would it take to lay on trailing arms? Thanks Later
Tony from Norcal
64shortc10 is offline   Reply With Quote
Old 12-30-2007, 03:33 PM   #2
PrerunnerRob
PrerunnerRob's Avatar
Re: layin frame?
Tony from Norcal
You are talking about the stock rear trailing arms right?
PrerunnerRob is offline   Reply With Quote
Old 12-30-2007, 07:07 PM   #3
64shortc10
64shortc10's Avatar
Re: layin frame?
Yes Prerunnerrob the rear trailing arms! I guess I should have made that part clear, sorry. I wanted to see pics of trucks bagged, blocked, Kp notched, modified or purchased trailing arm crossmember, on 20's to see if the are layin frame or how close to layin frame they are. Thanks for the help! Later
Tony from Norcal
Old 12-31-2007, 06:29 AM   #4
PrerunnerRob
Re: layin frame?
Tony from Norcal
I hate to break the news to you, but a KP notch is only half of the problem you are dealing with. I bought my truck thinking I could just weld in a notch make some bag mounts and call it done. The problem is the rear trailing arms come into contact with the frame before the rest of the truck can lay out. I'm running a 235/75/15 tire, which is 28.9" tall, 9.25 inches wide, so that puts overall tire height and width within a comparable 20" tire range. To get my truck to lay out, I had to start a notch right behind the front bed mounts. I built a frame clip on a bench out of 3x4 3/16 wall, positioned it, and welded it in place. After the rear clip was in, the rear trailing arm crossmember would hit the ground before the rest of the truck could lay out. I pulled the rear crossmember out, flipped it over to raise the trailing arm pivot point, and cut off the top and bottom surfaces. I replaced them with plate, transfered all of the mounting holes, and my truck finally laid out.
Here are some pictures.
So, since i"m going to do this all again, I would weld in a notch, and 2 or 4 link it. Trying to save the stock trailing arms is more work then it is worth, and by the time I had finished placing the bags, I would have to box the lower arms anyway. Where are you located by the way?
Old 12-31-2007, 07:53 AM   #5
SCOTI
SCOTI's Avatar
Re: layin frame?
Z-ing the rear frame 'clip' (from about the back of the cab) raises the frame rails to allow further drop w/o interference. You'll still need the c-notch/step-notch clearance. But if the rear clip is raised, you won't need as much of one.
It would prob be easier to just 4-link it. But. if you want the proven performance of the trailing arms & the rails to hit the dirt, it's going to take some work.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-31-2007, 08:37 AM   #6
gringoloco
A guy with a truck
gringoloco's Avatar
Re: layin frame?
You will not even come close to laying with the bags in the stock location. I did this on my Blazer and with a step notch I am still about 3" from laying.
You can move the trailing arm perches towards the center at the axle. This will allow them to clear the frame. Keep in mind, this will also push the rear axle back a few inches so you will need to move the crossmember forward to re-center it in the wheelwells.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-31-2007, 10:32 AM   #7
SCOTI
SCOTI's Avatar
Re: layin frame?
Originally Posted by gringoloco View Post
....You will not even come close to laying with the bags in the stock location. I did this on my Blazer and with a step notch I am still about 3" from laying.
3" was the number I remember when I played around w/my 67 in the garage. This is why I figure a 3" or greater 'Z' behind the cab could theoretically allow the rails to sit on the ground & still utilize the GM supplied trailing arm configuration. Some aftermarket round=tube style arms might help w/additional clearance but the cost would off-set the benefit (aftermarket arms prob cost as much as a weld-in, basic style 4-bar kit).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-31-2007, 10:40 AM   #8
gringoloco
A guy with a truck
gringoloco's Avatar
Re: layin frame?
Originally Posted by Spray-Bomb View Post
Couldn't he just add some blocks at that point ???
Isn't that what you did Gringo ???
I am using a 3" block just to get it that low. That is pushing the ragged edge of what is safe with a lowering block IMO. My trailing arms are within 3/8" of hitting the framerail at full dump.
Originally Posted by SCOTI View Post
Some aftermarket round-tube style arms might help w/additional clearance but the cost would off-set the benefit (aftermarket arms prob cost as much as a weld-in, basic style 4-bar kit).
True, plus the fact you will need a custom length panhard or watts...
-Chris
Old 12-31-2007, 12:31 PM   #9
PrerunnerRob
Re: layin frame?
All in all, in my opinion its just not worth doing all the extra effort to save the stock trailing arms. A conventional or triangulated 4 link will work better, allow alot more adjustment of pinion angle, axle centering, and operate smoother. You also dont have to deal with the pinion angle radicly changing throughout the travel arc. If you go with a triangulated, you don't even have to deal with a panhard bar. Just my 2 cents.
PS-my frame clip is getting cut off soon, if the person I told could have it falls through, it's up for grabs if anyone wants it.
Old 12-31-2007, 12:55 PM   #10
SCOTI
SCOTI's Avatar
Re: layin frame?
Pinion angle on a trailing-arm suspension (as described) is not going to change any more than what a stock set-up does. My modified stock set-up works well & is very stable based on my experiences in the truck. I've driven triangulated 4-bar set-ups that were much less stable simply because of the positioning of the bars based on pkging restraints.
Triangulated 4-bar, parrallel 4-bar, or trailing arm suspensions can all be made to work better than each other. Each has it's benefits; each can have negatives.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-31-2007, 09:35 AM   #11
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: layin frame?
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 01-01-2008, 06:17 PM   #12
gringoloco
A guy with a truck
gringoloco's Avatar
Re: layin frame?
There's pics in my "How to:" thread of the rear all the way down. The framerails are about 3" off the ground aired-out, but I am running a very tall tire(295/45-20). You could be as close as 2" with a 28" tire. You could easily put it on the ground by notching the rails for the arms or moving them in a little at the axle. I still have to trim the front fenders to put the front all the way down...
-Chris
Old 01-02-2008, 07:07 AM   #13
Kontrol Phreaks
Kontrol Phreaks's Avatar
Re: layin frame?
Here are some pictures of the C10 that I did on 22's, with factory trailing arms, bags off the front of the axle, KP notch. You could go lower with a set of blocks between the axle tubes and trailing arms. This truck didn't have them because the truck was level when aired out and that's what the customer asked for. Plus the 22's were bottomed out up front on the hood hinge and the crossmember was on the pavement.
Good luck with your project.
- Clint -
Kontrol Phreaks is offline   Reply With Quote
Old 01-02-2008, 07:14 AM   #14
Kontrol Phreaks
Re: layin frame?
If you were looking to go lower, then you could set the notch in a little higher and install the lowering blocks. DJM offers an adjustable lowering block kit which consists of (8) 1/2" thick plates and new U bolts. So you can lower each side anywhere from 1/2" - 2" inches.
You're going to need to relocate the shocks as well now the upper mount will be gone, and the angle off the trailing arms would be radical. The truck shown above uses our rear shock relocation kit and a new shortened pan hard bar with a 3 degree cope on the frame side, and a 3/4 heim joint on the axle side.
Later.
- Clint -
Old 01-02-2008, 12:58 PM   #15
XXL
Seρor Member
XXL's Avatar
Re: layin frame?
[QUOTE=Kontrol Phreaks;2509453]Plus the 22's were bottomed out up front on the hood hinge and the crossmember was on the pavement.
The math doesn't work for me... if you've got a 27" tire (ASSuming, based on the 22" wheel), and you're on the stock hinge up front, the xmember isn't on the ground. Am I missing something from your explanation of what was done??
XXL is offline   Reply With Quote
Old 01-03-2008, 04:39 PM   #16
c10addict
c10addict's Avatar
Re: layin frame?
Up front I am running drop spindles with front airbag cup cut down to 1 inch. Out back a kp notch with a 2 inch block... I relocated my rear bags to the rear axle... With this set up the trailing arms touch the frame when dumped and the frame sits level.... with a 29" tire the bottom of the middle of the frame is 3 inches off the ground... It will drag the sh*t out of the rear license plate box but thats about it...
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08
67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast.
64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten..
54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread...
07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind..
http://67-72chevytrucks.com/vboard/s...d.php?t=339340
See pics of my trucks in my profile
c10addict is offline   Reply With Quote
Old 05-07-2008, 11:43 AM   #17
1963chevyshort
New Member
1963chevyshort's Avatar
Re: layin frame?
Well Tony hey when are you going to show us some pics?
Anthony
63 chevy stepside SWB
57 chevy 2dr hrdtop belair
1963chevyshort is offline   Reply With Quote
