Old 01-01-2008, 06:10 AM   #1
NEVERENOUGH
NEVERENOUGH's Avatar
Heater problem
Ok here is the deal working on my daughters 79 swb 4x4 she just turned 16. I can't get the dang heater blower to work. I can direct power from battery to blower motor and it works. I check the blower motor wire with a test light and I have power. I can't get it to work with the main power just plugged into the blower motor. I changed the relay switch on the ac still no luck. Could it be the switch inside the cab? Any help is appreciated thanks.
NEVERENOUGH is offline   Reply With Quote
Old 01-01-2008, 09:11 AM   #2
Shamil
Shamil's Avatar
Re: Heater problem
i had the same problem. the problem was with the wire from the fuse box to the switch, i think it is color brown, once i replaced the cable the blower worked.
Shamil is offline   Reply With Quote
