Old 01-01-2008, 02:46 PM   #1
jerry moss
Born Psycho
jerry moss's Avatar
Question rear shackle flip ???
anyone here using the off road design shackle flip? i just did the exhaust system on a customer's blazer and he had one installed on his truck. he hasn't used it yet so i went to the website and read about it, 4 inches of lift with no blocks.last year i purchased a brand new 4 inch lift kit off craigslist- tuff country, front springs, rear blocks, shocks, steering arm and hardware- for 150 bucks but i'm not a fan of blocks since i've rolled two sets of 4 inch blocks in the past. if anyone has experience with this company, i'd be interested in your feedback before i order a set. thanks in advance.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 01-01-2008, 03:09 PM   #2
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Re: rear shackle flip ???
I have never used the shackle flip but you might try Yukon Jack, he has one on his 69 flatbed and from what I have heard they work great.
I can however vouch for the company, I have used Off Raod Designs greasable heavy duty shackles and there heavy duty upper spring eye conversion along with there croosover steering setup...all great products that are of high quallity.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 01-01-2008, 03:38 PM   #3
OLDCHEV4X4
OLDCHEV4X4's Avatar
Offroad design is good stuff. They have there own message board over on the CK5 web site.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 01-01-2008, 03:37 PM   #4
Yukon Jack
Yukon Jack's Avatar
The only thing I don't like about the shackle flip was it moved the rear axle forward a bit and when I had the fleetside bed on my 69 K20, I didn't like the look. Doesn't matter at all now that I have the flatbed on there. A Zero-rate block from ORD could be used to help get the rear axle centered in the wheelwell after doing the flip. I have hauled a bunch of wood on the truck and pulled a few heavy hay trailers and have never had any issues with the flip. It is well built product.
Here's a link showing the install of the shackle flip and here is a pic prior to the flatbed which shows the placement of the rear axle after the flip.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-01-2008, 04:15 PM   #5
NEVERENOUGH
NEVERENOUGH's Avatar
I haven't used one but am going to on both my son's blazer and my daughter's 79 swb. I do know that Stephen owner of ord wheels his stuff and uses it. I have talked to him on the phone a couple times seems to be a great guy to deal with.
NEVERENOUGH is offline   Reply With Quote
Old 01-01-2008, 04:35 PM   #6
DieselEater
DieselEater's Avatar
It's a tough product that works great...I made my own axle offset plates to put the rear end back where it should be. Not to take anything away from ORD....but it would be fairly simple to make your own with a welder and a chop saw.
A.....
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
http://profile.myspace.com/index.cfm...ndid=127691959
DieselEater is offline   Reply With Quote
Old 01-01-2008, 05:12 PM   #7
cobinder
Everything is work in progress
cobinder's Avatar
I got a set and I love'um. Mounted right up, springs and flex more. If you have a lot of arch in your springs it will move your axle a bit. My springs have about 5" of arch and it didn't noticably move my axle.
The fit and finish is first rate.
Check your pinion angle when your all done. I didn't have to adjust mine, but some might.
Good luck with your truck!
How much?! It's just an old truck part!!
49 International on a 80 GMC 3/4ton 4x4 chassis
48 International KB-5 2 ton dump bed
04 Honda CRF "500"
09 Honda CRF450 fuel injected rocket
03 Suzuki hayabusa carbonfiber wheeled monster.
02 Ford diesel stretch van (toy hauler)
01 38' Monaco diesel pusher motorhome
cobinder is offline   Reply With Quote
Old 01-01-2008, 05:22 PM   #8
jerry moss
Born Psycho
jerry moss's Avatar
Thumbs up Re: rear shackle flip ???
thanks for all the replies, looks like i'll be ordering a set for my K/5
jerry moss
Old 01-01-2008, 06:14 PM   #9
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
I got em’ too. Good stuff. Pre-’73 truck definitely need the zero rate spring to move the axle backward in order for them to look right. That doesn’t seem to be a problem on ’73 and up.
My truck has become a rolling bill board for ORD lately. I have the 4” rear shackle flip, heavy duty front greasable shackles, sway bar disconnect, steering box brace and high clearance HD engine cross-member.
Here is the link to the shack flip project…
http://67-72chevytrucks.com/vboard/s...d.php?t=243827
DirtyLarry is offline   Reply With Quote
Old 01-01-2008, 06:52 PM   #10
cobinder
cobinder's Avatar
Jerry, look at this site if you haven't already.
www.colorado5k.com
Larry I got ya beat for the ORD poster child.
Dana 44 crossover with highsteer and 1-1/4" tierod and draglink.
HD engine crossmember (love it)
4" shackle flip
Greasable leaf bushings all the way around.
zero rates in the rear
Front shackles
Comp bumpstops.
LOL
04 Honda CRF "500"
Old 01-02-2008, 04:25 PM   #11
dbcox
dbcox's Avatar
I got a set on a 83 3/4 ton. i love em the truck flexes more and rides better than the blocks did.My rear did not move foward hardly any but i do need a shim to roll the rearend just a bit. I have had them about 6months with no issues. i posted some pics of them here a while back you might could search and find nthem
dbcox is offline   Reply With Quote
Old 01-02-2008, 05:40 PM   #12
Husker
Husker's Avatar
If you use the shackle flip you do not need new springs for the rear, just for the front?
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 01-03-2008, 04:24 AM   #13
jerry moss
Born Psycho
jerry moss's Avatar
Ron,
thats correct. the one i worked on had the shackle flip plus 2" blocks in the rear and 6" springs up front.
jerry moss
Old 01-03-2008, 04:46 AM   #14
I have a pair of 6" front springs for my shortbed K/30.I will use the shackle-flip and 2" EZ-Ride springs.Along with a list of ORD goodies.I ordered the flip-kit once and the money order never made it.By the time BOA reimbursed me it was over 3 months later and the money went elsewhere.
