01-01-2008, 04:54 PM | #1 |
help
My sons 72 is giving him a problem.It will run for a while and then act like it runs out of gas.He's already changed the fuel pump,filters and carb.Theres is no dirt in the gas as he has a clear filter on it and the gas looks clean.When it sets awhile it will crank right back up and run for awhile and do it again.Im the one that works on his truck but I've been sick lately and can't help him.Any ideas.Thank You
77 swb starting all over again. |
01-01-2008, 05:16 PM | #2 |
I'm already on the flipside.
Re: help
Sounds like you might have a vapor lock problem.
01-01-2008, 05:30 PM | #3 |
Re: help
Try routing the fuel lines away from the manifold/header's and anything else that gets really hot.. If it is vapor lock this should help.
01-01-2008, 05:31 PM | #4 |
Re: help
Got this from Wikipedia,
Vapor lock is a problem that mostly affects gasoline-fuelled internal combustion engines. It occurs when the liquid fuel changes state from liquid to gas while still in the fuel delivery system. This disrupts the operation of the fuel pump, causing loss of feed pressure to the carburetor or fuel injection system, resulting in transient loss of power or complete stalling. Restarting the engine from this state may be difficult. The fuel can vaporise due to being heated by the engine, by the local climate or due to a lower boiling point at high altitude. In regions where higher volatility fuels are used during the winter to improve the starting of the engine, the use of "winter" fuels during the summer can cause vapor lock to occur more readily. |
01-01-2008, 05:28 PM | #5 |
Re: help
Not to sound dumb but what does that mean?[vaporlock]A guy on another site was describing the same thing on his 56.They told him to try running it with his gas cap off.Does that sound right?
01-01-2008, 05:45 PM | #6 |
Junior Member
Re: help
You might want to check all the rubber fuel lines.
I had one on the suction side of the fuel pump that was collapsing causing similar problems. If the gas tank or cap are not vented a vacuum can happen causing problems and losing the cap can remove the vacuum affect allowing the gasoline to flow. Danny - Southeast Missouri |
01-01-2008, 06:17 PM | #7 |
Re: help
I would start looking at the ignition system. Does it have Electronic Distributor? Could be Coil or Module.
01-01-2008, 09:12 PM | #8 |
yes, i do
Re: help
i would check the timing as well
ERROR 404....... SNAPPY COMEBACK NOT FOUND _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
01-02-2008, 03:49 AM | #9 |
'71 chevy s.bed/s.side
Re: help
Back to the basics. It takes fuel, air & spark (electrical) to make an engine run. Usually vapor lock will not occur until the fuel temp rises significantly. Make sure he has plenty of gas in the tank - remember simple things first.I would also check the gas cap. remove it and see what happens. Also check that fuel filter one more time. He could have a tank full of trash. If you're getting fuel, check the components of the electrical system. I've had a coil to cause the same symptoms that you're speaking of. Let us know what you come up with, and good luck! Hope you get to feeling better fast!
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! |
01-02-2008, 03:08 PM | #10 |
Re: help
Talked to my son.He is going to try some of the things ya'll said to try in the morning.Tonight were making tamales oh yeah can't wait to taste them.Happy New year Guys& Ladies.
01-02-2008, 04:13 PM | #11 |
Re: help
theres a filter sock on the fuel pickup inside the tank not unusual for that to be clogged with crap
01-02-2008, 05:12 PM | #12 |
Firefighter
Re: help
I had a problem like this, I would start the truck and it would run fine for a minute or two then act like it ran out of gas and die, I could pump it and it would restart and do the same thing over and over. I replaced all of the fuel lines and it would still do it, I got a wild hair one day and took off the air breather while it was running and looked at the choke butterfly and it would start to open too soon and the truck would die, so I bent the choke rod so it would stay closed a little longer. It fixed it and I haven't had it happen since, so you might check that also.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA |
01-03-2008, 03:02 AM | #13 | |
Old Skool Club
Re: help
But, there's a deeper problem with Sears.....that being the simple fact that they could fix anything, as long as your credit was good and you had ample room on your credit limit. I saw other issues besides that one. I seemed to be the one to get the stuff nobody else could fix, and never did I get one that hadn't been muffed up, leading the customer to spend more money than he/she should have had to spend. Just read a Custom Classic Truck (Jan) issue that tells of taking a '95 Camaro in for plugs/wires, only to find that the six used plugs he got back were what got changed. The other two plugs in the V-8? Still there. Plug wires were routed too close to the exhaust manifold, and they didn't live 200 miles. Vapor Lock? I have not seen such since my dad sold our '50 Plymouth, in '59. Used to see people come in the station I worked at, with clothes pins clamped onto the steel fuel line, to "prevent" vapor lock. Not gonna say it doesn't happen, I just don't have any experience with it, and I try to stay true to the routing of fuel lines, as the factory intended. My '69 had a problem in which it would die. Being I am older and not as agile as I once was, I let someone I trusted work on it. Only thing is he wasn't doing the work, just one of his employees. After replacing the ignition module in the HEI, it seemed okay, until New Years Day, 2003 (about a month later). To make a long story short, I put in a new Accel HEI. The problem with the old HEI? The wire to the reluctor had an intermittent break in it that would become an open circuit when you let off of the gas and the vacuum advance would move it enough to break the circuit. Don't know if you have HEI, but don't let this tidbit throw you off. I only put it in here JUST IN CASE you exhaust all the normal options and have questions. In the medical world, the problem I had is a zebra, when you should be looking for horses when you hear hoofbeats.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
01-02-2008, 05:45 PM | #14 |
Re: help
Here is my .02 And Im not too cool to admit this happened to me. I was having the same problem and here is what it was. I have a C-20 with two fuel tanks. When I was getting in and out of the cab my foot accidentally hit the Tank selector valve on the floor between the door and the seat. I hit it just enough to put it in between the two tanks. I dont even want to tell you how long it took me to figure out that one. I havent felt that stupid in a while...
They sure don't make 'em like that anymore |
01-03-2008, 05:04 AM | #15 |
Sierra Grande Club
Re: help
Nobody backs you like Sears! Anybody remember the problems they had with there brake jobs in the `80's?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
01-03-2008, 07:09 PM | #16 |
Re: help
had that problem on my 71 custom10 turned out to be rubber fuel line on fuel pump suction side was collapsing
71 custom 10LWB 96 thunderbirdLX(wifes car) 04 F350XLT 05 peterbuilt379 550 twin turbo cat. 72sterncraft whoever dies first with the most toys wins |
