Old 01-03-2008, 01:57 PM   #1
69GMC4x4sdca
which bbc oil pan
Installing 454 in a 1969 GMC K 2500.Have relocated engine crossmember forward about two inches.The oil pan I have will not clear crossmember.Does anyone know which pan I need to use.Any help would be appreciated thanks.
69GMC4x4sdca is offline   Reply With Quote
Old 01-04-2008, 05:53 AM   #2
Yukon Jack
Yukon Jack's Avatar
Re: which bbc oil pan
My 454 and it's oil pan that I put in my 69 K20 came from a 1989 2wd 1 ton and the clearance was very close at the oil pan - I used a couple washers to raise the engine a touch. Without the spacers there was maybe 1/8" of clearance.
Offroad Desing has a custom engine crossmember which fixes this problem I believe.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-04-2008, 05:54 AM   #3
Yukon Jack
Yukon Jack's Avatar
BTW, can you post some pics of your engine placement? Did moving the engine forward 2" fix your firewall issues or did you do anything else?
Old 01-04-2008, 05:35 PM   #4
69GMC4x4sdca
Yukon Jack thanks for your reply.Height of engine is not an issue.The pan I have when the engine is lowered into postion the pan is against the crosmember and will not set down all the way.Have already ruined two crossmember trying to modify them to get engine to fit.Crossmember is the original sbc type.Here are a few pics.Guess I need to find a different oil pan and try it.
Old 01-05-2008, 05:53 AM   #5
Yukon Jack
Yukon Jack's Avatar
Could you get your hands on an 73-up crossmember? I think they give better oil pan clearance - PM burt4x4 to find out for sure, he was using one for a while with his bbc.
Old 01-12-2008, 06:38 PM   #6
mosesburb
I had a V-8
mosesburb's Avatar
'73 and up mount brackets and x-member will fix your problems. When I put a GenV BBC in my '72 I pulled the pan and cut the offending area out and welded in a couple flat plates to cover the hole I created. It worked out good, but if I had it to do again, I think I would go with, at a minimum, the frame brackets for the '73 up and ideally make my own x-member or as a last resort, install the x-member for the '73 up.
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
Old 01-13-2008, 06:07 AM   #7
Burt4x4
Burt4x4's Avatar
If I had to doit again I would get DIY4X's first gen crossemember. Works great.
This is the 73+ crossmember it was a ***** to get in there but it worked, then it cracked. It was about 1/8" from touching...
Replaced the cracked one with ORD's x-member...still VERY tight, but not touching.
The engine does not move or twist in it's mounts, ORD engine mounts, so being so close doesn't seam to be a problem. But if I have to do it again the DIY4x solution is a much better fit with room to spare. I can't remember who it was that put one in..might be over at CK5 in the first gen fourm there.
Good Luck hope this helps.
Oh my oil pan is GM, not sure of the prt number as my engine guy scored it for me. It has the windage tray & flaps inside to help prevent oil sloshing about.
Burt
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 01-13-2008, 07:03 AM   #8
green724x4
green724x4's Avatar
69GMC4x4sdca
Did you have any issues with header or exhaust manifold clearance after moving your motor mounts forward? What are you running for headers if so? Do you have clearance issues with the radiator? Sry if I hijacked the thread.
green724x4 is offline   Reply With Quote
Old 01-15-2008, 05:36 AM   #9
69GMC4x4sdca
Thanks to all that responced.Found the DIY4X site and have ordered their first generation crossmember.Will post some pics when installed.Plan on running stock exhaust manifolds for now.Should not have any radiator clearance issue I hope.
Old 01-16-2008, 10:05 AM   #10
'71c204x4454
'71k204x4454
I also run stock exhaust manifolds. Before you install them there is a little nub sticking out on the drivers side torward the front that you will have to shave off. Well I had to any way but I didn't move mine forward but it will save you some headache just in case.
1971 K20 4x4
1964 buick skylark convertible
'71c204x4454 is offline   Reply With Quote
