01-03-2008, 04:40 PM | #1 |
HERE.......Somewhere
Antenna stock or not?
Why does it have a spring at the bottom?
Current rides: 2013 Hyundai elantra gt DD 1995 camaro my first crush lmao Was: 1970 with a 350 4barrel and 288 horses Classics make it possible! |
01-03-2008, 05:11 PM | #2 |
Zappaphile!
Re: Antenna stock or not?
Not. So the antenna can flex and will not break off as easily if it gets hit in a carwash, by bird, angry husband, etc..
1969 C20 LWB Camper Special - The Beater.. 1998 Cheyenne V6 - 4/6 Drop - For The Son |
01-03-2008, 05:12 PM | #3 |
what does the stock one look like. What did mine come off of?
01-03-2008, 05:12 PM | #4 |
Official Site Guitar Shredder
Not Stock.........seen them on alot of our trucks...but there not stock......
01-03-2008, 05:16 PM | #5 |
Zappaphile!
I dont have a pic of the stock one. Base is a little more flat, antenna screws onto the base. Yours, is probably off the shelf from Radio Shack.
01-03-2008, 05:24 PM | #6 |
That there is what ya call "Redneck Bling". CB radio antennas in the 70's had springs to keep 'em from breakin' off in high speed driving! No, really!
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
01-03-2008, 05:27 PM | #7 |
I am so gettin one of those then...
93 Sonoma 2.8/5spd 75 Malibu Classic 350/350 If it don't have round headlights and a carb, I don't trust it! |
01-03-2008, 06:05 PM | #8 |
its all about the +6 inches
the spring base ant was a common thing back then,k-mart, radio shack, sears & robuck... even TG&Y had these on the shelf by the craig and craco radios.
Your truck doesn't even look like it had a radio originally, the hole there is too small and not in the right location. |
01-03-2008, 07:30 PM | #9 |
Zappaphile!
Wow, TG&Y. You are putting an age on yourself now. Let me see if I can find my Beno's card..
01-03-2008, 06:17 PM | #10 |
Better remove the radio and weld up the holes.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs. 84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80 68 GMC C20 Parts? Truck And a few cars |
01-04-2008, 02:29 AM | #11 |
Boosted Member
I like the way you think!!
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
01-03-2008, 06:34 PM | #12 |
Now I am curious if mine antenna stock or not?
01-03-2008, 07:32 PM | #13 |
Zappaphile!
I regret to inform you it's also probably not a stocker, but could be a dealer installed job. Stocks were screw in with a flat base. Will try to get you some pics tomorrow..
01-07-2008, 06:30 AM | #14 |
please, try and get those pics of the stock ones.
01-07-2008, 03:13 PM | #15 |
Firefighter
Other truck
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA |
01-04-2008, 01:27 AM | #16 |
Stock antennae were 31" and non-telescopic.The spring-type were cool since delinquents liked to snap off antennae back before they started hood ornaments.
01-04-2008, 02:39 AM | #17 |
KEEP ON TRUCKIN'
The ones with springs work well on 4X4's if you like to take it off road. My K10 has the solid non-telescopic type and appears to be original to the truck.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" |
01-04-2008, 03:47 AM | #18 |
Old Skool Club
Wait a minute.....weren't the originals telescopic?
The fixed-length antennae didn't exist until the proliferation of FM broadcasts. The fixed length was determined to be 31-inches, based on the wavelength of the signal that the FM stations transmitted. The telescopic antennas were adjustable to let the listener adjust it to get a better AM signal. Back in the day, there were procedures in the owner's manuals that told you how to adjust your radio and antenna to get the best signal from the AM stations that we had. It involved setting the antenna to a shorter position, then pulling the tuning knob off of the radio, to gain access to the adjusting screw that was behind it. You would then turn that adjuster to peak-out the received signal that you was the station. Fixed length antennas didn't come out until like '73 and later, for automotive uses.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
01-04-2008, 09:26 AM | #19 | |
Freeeeee Mason...
My stock replacement is telescopic. |
01-04-2008, 09:44 AM | #20 |
Ok,I`m thinking of the fm antennae.That`s what I run on mine.I think the 71/72s were one piece.Maybe there was both.
01-04-2008, 09:50 AM | #21 |
My '70 has one with a spring as well and had wondered where it came from. Probably going to end up replacing it.
1970 C10 - ECE 3.5/5 drop, dual exhaust with turbo mufflers, front discs http://67-72chevytrucks.com/vboard/s...d.php?t=272458 2000 Buick Regal GS - Supercharged 3.8 V6 240hp, 1/4 mile 15 seconds |
01-04-2008, 10:54 AM | #22 |
I've got a hick whip and my original telescoping antenna its longer than the hick whip
01-04-2008, 11:25 AM | #23 |
Just for the record, my 72 cheyenne super with an am radio is an telescoping fixed (non-spring) antenna... AND I am having a devil of a time re-placing it in the cowl hole in order to tighten the locking nut, but thats for another post....
--Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
01-04-2008, 12:14 PM | #24 |
WTB this ad
My C10 has a telescopic antenna that appears to be stock. That thing is huge when I extend it the whole way!
01-04-2008, 01:15 PM | #25 |
Firefighter
My 72 has a non telescopic with spring, it looks just like my Grandpa's 72 which he bought brand new, and the antenna was on it from factory.
