![]() Join Date: Nov 2006
heim joints vs bushing ends?
are heim joints any good looking @ fbirides.com
the 73 complete 4 link kit? are heim joints strong enough, safe, reliable? thanks for help looking to put it on my 84 crew that i converted to 1/2 ton suspension? Last edited by duceducenine; 06-12-2008 at 08:23 PM. |
Re: heim joints vs bushing ends?
get on ***************** they have the heaviest duty overkill stuf around, i saw on nissancustom.com this same question and they said *****************. i got a 4link kit from a local race shop and couldnt make the heims work without a pan hard bar so i got the heavy duty triangulated 4link kit fron suicidedoors and thats stuf is stout, it puts that other stuf to shame. check out the difference! hope this helps
the fab shack
if you get the GOOD heims, XM, RSM type from places like ballisticfabrication.com then yes, they are good. The heims that FBI uses are very cheap and wear out very quickly.
A full bushing 4 link doesnt give a lot of movement, so if you just plan to roll and not really flex your truck around (i.e. sides, try to 3 wheel, etc) then bushings are fine. If you want some movement in what you build, then heims or johnny joints are the way to go. suicidedoors is fine, but i order most of my stuff from gravity-werx.com |
vote #2 for suicide doors ... very well known and reputable, as opposed to some
belly dragger
I use bushing ends or joints such as super flex joints or johnny joints. Everyday street use is not the place for heim ends in my opinion.
SAVE THE PLANET DRIVE AN OLD TRUCK Last edited by grnddwn; 01-07-2008 at 09:03 AM. |
#6 | |
Señor Member
![]() Road grime plus Heim = prematurely worn out, noisy, sloppy connect points. If you're going to drive it, use bushings.
the fab shack
Señor Member
Sealed? It's a metal spherical bearing. Regardless of what you want to wipe them with, they're subject to the same laws of nature as any other metal moving part. Since my comment was tied to "daily driving" can you point out examples where automobile manufacturers (who have spent LOTS of R&D dollars on cost-effectiveness, durability, and reliability for their moving suspension parts) use Heim joints? They use rubber (urethane, graphite, whatever) bushings for a reason.
#9 | |
the fab shack
They are a spherical bearing and they do move and eventually wear out, the ****ty ones wear out really quick, the GOOD ones last you 20-30-40k miles, if not more. You act like they instantly get dirt in them and are junk.. they are like Uniballs.. they move, but they the contact area is sealed off.. when the joint pivots, you're not dragging rock and **** into it, there isnt a huge gap there.. hell use the heim dust boots if you're worried then. Just like johnny joints, they need rebuilt at some point.. bushings are fine, but if the guys wants movement he needs to get a heim or johnny joint.. i use bushings b/c i never hit sides, but some ppl do and they need to be told what their options are for what THEY want, not what everyone else wants. |
the ones i got from that race shop didnt even have grease fittings! thats metal on metal! i bet they squeek too!
the fab shack
You can get a heim that is everyday.. they last 20-30k if you get a good heim.
metal to metal heims is what i think FBI is using, if not they are the cheap kevlar ones (there are better grade kevlar ones).. Heim's do not need a grease joint as they are self contained. It is what quality you get as to if they will last or not. Being self contained, they dont get anything in them to damage them. these are pretty decent heims. http://www.ballisticfabrication.com/...p_84-1423.html |
yea those are alot nicer than the sh!ts i got
Hollister, CA.
![]() Join Date: Sep 2006
If you purchase a QUALITY heim from a fab or race shop...then you will not have any problems.....
Just to give you an idea....back in the day...we used to use "hardware store issue" ![]() We put TREMENDOUS amounts of load of those things...side and straight on loads. Those darns things would bend and the end of the shaft, and stay together. The entire side weight load of a 65 Impala, up on three wheels, all supported by a heims-joint and one rear corner...not bad for a $9 Orchard Supply Hardware store heim !!! So if you aquire some quality ends, they will last, for sure !!! Especially just a suspension link.
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 01-11-2008 at 03:37 AM. |
Do not buy fbi's heims I agree with previous responses fbi is local to me and I know a lot of people down there owner and manager included. But like I said there heims are garbage (to say it in a nice way), they carry a lot of good stuff but heims are not one of them I will get info from my buddy who owns BC Fab and see what he uses, there a good quality heim but they cost twice fbi's
I prefer bushing ends or superflex joints, superflex's are greasable, easily rebuildable, there like a spherical bushing, Like putting a bushing and a heim in a blender
1968 Short Fleet 350/700r4 http://67-72chevytrucks.com/vboard/s...d.php?t=249435 1997 Bagged XtdCab Vortec350/4L60e http://67-72chevytrucks.com/vboard/s...44#post2286144 1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver" 1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap Last edited by Scott68-93-97; 01-11-2008 at 08:57 AM. |
#15 |
thanks everyone for your help looks like i wont be doing heims.......
#16 |
Junior Member
XXL you are right.... for a daily driver you want to use a bushed end... better yet a compressed rubber bushed end link. Heim ends will work for daily drivers in a panhard bar situation but on a link bar ... definitely bushed or rubber.
The best heims you can get on the market are kevlar lined heim joint. The problem is like XXL mentioned... you will eventually get small debris between the kevlar and the metal ball or outer shell. Once that happens... you loose tolerance and the rod end is done. |
#17 | |
belly dragger
![]() Quote:
SAVE THE PLANET DRIVE AN OLD TRUCK |
#18 |
thanks guys for the info i just bought a kp 6 link.......
#19 |
A guy with a truck
Cool.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#20 |
belly dragger
Good choice !
#21 |
Happy to be here
![]() Join Date: Mar 2000
Thanks for stepping in Tony...
#22 |
Junior Member
No problem man....... I post when I can. If you people would quit calling me I would have more time to screw around.......
#23 |
Surviving, one day at a time!
bulletproofsteering.com has some nice rod ends if your using 3/4-16 with a 3/4 bore.
