10-15-2002, 11:42 PM | #1 |
[]D [] []v[] []D
brake light
its been a while since i posted but ive recently lowered my truck 3/4 with a belltech kit and it looks pretty goo but anyways when igot my truck almost 2yrs ago all lightsworked (brakes, blinkers, etc.) but slowely my passenger side light has stopped workin first the blinker stopped then the brake light now the whole light is out and its a new bulb and i took out the assemby from what i can see its fine so i figured its the wiring and i dont have any diagrams or such so any help or remedies would be nice thanks
Clint 72 c'10 350ci/400hp sleeper forever |
10-16-2002, 12:21 AM | #2 |
L.E.D. Freak
Check ground wires first make sure they're tight and bare metal connections. Maybe need new flasher? Cheap might as well get a new one.
Specializing in Custom L.E.D. inserts. http://www.ccled.com/ Contact me @ blazer2wd1972@hotmail.com (406)675-8082 or Joel @ jmcwaters@eps-corp.net 1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL |
10-16-2002, 12:26 AM | #3 |
[]D [] []v[] []D
checked the grounds
and there fine but what do u mean flashers???
10-16-2002, 07:59 AM | #4 |
67-72 Addict!
He means the hazard lights switch that plugs into your fuse panel.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
10-16-2002, 10:30 AM | #5 |
wiring
I encountered something in the old wiring category last weekend.
Neither my cargo lite or dome lite were working. I found the following. - fuse ok -12v at connector at fuse block - continuity ok on white (grd) wire on both circuits - no continuity on either hot So I stripped the loom off the full length of wire to look for obvious breaks, etc. On the dome, I found a mickey mouse repair and thought that must be it. Checked cont form fuse block to repair and had cont. from the other side of repair (after separating the wire at the repair) no cont. No visible problems in wire, but no continuity! I went about half the length between the repair and the terminal end and shaved a little insulation off. Checed continuity both ways, good one way, not the other. I then noticed a little irregular bump in the wire in the no cont section. Stripped the insulation and found a white oxidized powdery mess about 1/2" long where wire once was. I cut out the bad and spliced in some good and got 12v from the fuse block to the end! Found the same thing in the cargo lite circuit. All I can figure is that along the way a pinhole got in the insulation somehow and let moisture in allowing the corrosion. It was weird, though, because there was no visible sign of any hole/breakage in insulation.
Dutch 1972 Super Cheyenne K20 1976 MGB 1950 Harley FL 1997 Arctic Cat ZR580 "Maybe if I had a couple less hobbies, I'd have time to enjoy one!" |
10-16-2002, 11:25 PM | #6 |
its all about the +6 inches
Since it all went out slowly, and not at once, I am gonna make a guess on it.
pull the bulb, and (with the lights off) spray some electrical motor cleaner in it, and clean out any grease/gunk/crap that is in there. Seen it many times. |
