01-09-2008, 05:28 PM | #1 |
Glovebox Replacement
I'm having this problem installing the new glove box I bought. The bump stops for the glovebox door are not letting the glove box line up properly. Am i just doing this all wrong or what? Does any one have a picture of a installed new or old glovebox? Just to give me a reference point. It would me much appreciated.
01-09-2008, 06:01 PM | #2 |
Easy Does It
Re: Glovebox Replacement
make sure the box and bump stops are facing the right direction- the box has to slide into the glovebox door hinge along the bottom and clear the top. it could be the lock striker on top needs adjusting?
01-10-2008, 05:50 AM | #3 |
Check your mounting screws in the corners , back off on them some till you get it adjusted rigth then tighten them down. If i remember right mine had some play for adjusting on the corner mounting screws.
01-10-2008, 08:01 AM | #4 |
I am also having issues getting the new box to align. Pics would be nice. Hint. Hint.
Daniel 66 Chevy C10 LWBSupport our troops! |
01-10-2008, 11:41 AM | #5 |
When i get home i will see what i can come up with.
01-10-2008, 05:29 PM | #6 |
So is it the door or the actual cardboard replacement you are referring to?
