Old 01-11-2008, 07:18 AM   #1
Hart_Rod
Hart_Rod's Avatar
New LT-1 parts F/S
I've have several extra LT-1 parts left over from my 48 5 Window that I recently sold.
Like new CS130 alternator (<500 miles)
new water pump
new power steering pump with aluminum pulley
Set of high mount Alan grove LT-1 brackets (Alternator and AC)
Miscellaneous gaskets and fittings
I would like to sell as a package, but might separate. $300 o.b.o. + shipping for everything.
I also have a Carolina Rodshop fiberglass cover that was designed to cover up the throttle body and fuel rails on the LT-1. **** Cover SOLD to KHOULT pending payment. ****
Thanks,
Hart_Rod is offline   Reply With Quote
Old 01-11-2008, 07:20 AM   #2
Hart_Rod
Hart_Rod's Avatar
New LT-1 Parts
http://www.67-72chevytrucks.com/vboa...d.php?t=273543
Old 01-11-2008, 10:00 AM   #3
faribran
Re: New LT-1 parts F/S
Rob,
I might be interested in the AC mount, if u decide to seperate.
i need to mount my A/c compressor so it clears the frame.
faribran is offline   Reply With Quote
Old 01-11-2008, 10:17 AM   #4
Hart_Rod
Hart_Rod's Avatar
Originally Posted by faribran View Post
Rob,
The a/c and alt brackets have to be run together, you can't mount one or the other. How about a deal on all of it?
Old 01-11-2008, 10:33 AM   #5
whatnow123
whatnow123's Avatar
I don't know my chevy nomenclature much, but I'm assuming this won't work on the up to 86 small block right?
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 01-11-2008, 03:16 PM   #6
Hart_Rod
Hart_Rod's Avatar
It will bolt up, but getting everything to line up would probably take some engineering.
Old 01-11-2008, 03:50 PM   #7
khoult
i'll take the cover.
khoult is offline   Reply With Quote
Old 01-11-2008, 10:02 AM   #8
faribran
i also need the air filter box for the Lt1 set up.
i have the top half.. need the lower half
Old 01-14-2008, 11:14 AM   #9
Hart_Rod
Hart_Rod's Avatar
bump
Old 01-14-2008, 02:17 PM   #10
OJOE
Crew Cut
OJOE's Avatar
i may need the other parts, sending pm
just make me a deal on everything you have left, what air compressor does it take ? do you have one? remember i am a poor boy from alabama
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 01-16-2008, 01:56 PM   #11
Hart_Rod
Hart_Rod's Avatar
SOLD!!! to OJOE
