Front and rear sway bars with bags?????
I have a idea on what I am going to do for the front bar, I am going to run a nascar style since I no longer have the fractory frame rails or front suspension. On the rear what are my options? I am going to be cramped for space with the bags in front of the axle and the watts on the rear. I was thinking again about using the nascar style and mount it behind the axle and attach the end links to the axle. Will that work??
Thanks guys http://www.stockcarproducts.com/susp21.htm http://www.stockcarproducts.com/susp22.htm Last edited by jkade; 01-12-2008 at 11:28 AM. |
Re: Front and rear sway bars with bags?????
This is kinda what I am thinking for the front.
Anyone????
A guy with a truck
I like that. Would look good polished up. Have you thought about mounting the rear to the trailing arms? You may find more room up there without all the clutter. Also, would a Corvette front bar work for you?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
Junior Member
Yes.... what you are talking about doing with work just great.... I cant tell you how many times I have recommended those torsion sway bars to guys and they look at me like I am on crack
#6 | |
Good thing is that they are not that expensive and if they are good enough for nascar they should be good enough for a street truck. |
Junior Member
Ive got em on the front and rear of my 61
Junior Member
![]() Join Date: Aug 2005
A Camaro rear bar might be an option depending on how much travel you'll have with your bags.
#11 | |
A guy with a truck
![]() Aren't you ditching the Camaro bar? Is it incompatible with your current amount of lift?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 01-13-2008 at 02:20 PM. |
#12 | |
#15 |
Regular guy
I'll be running torsion sway bars on my 77.
The rear is done and I'm in the process of fitting the front now that the dropmember is in.
'Frank' 77 Silverado 18 & 20 American CL205s Edelbrock MPFI, 700r4, Baer Brakes 9" F@rd rear, Vintage air, Bags etc etc.. |
#16 |
#17 |
OK, I thought I was pretty up on different sway bar configurations but I've never seen the torsion sway bars.
Where do you get them? Do they have to go through the frame like that or could the tube be mounted under or over the frame rail? I like the idea and the look. Can you get the torsion bars in different diameters and lengths to tune the suspension? 7T7, I love your set-up. It's very clean. ![]() Where are you mounting your tanks and compressors and where is your exhaust gonna exit? I'm also curious why you have the disc brake on the diff and on both wheels? Do you have a build thread? It'd prolly answer some of my questions.
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver Last edited by babyblueoval; 01-15-2008 at 04:55 AM. |
#18 |
Formerly ADHDCARGUY
jkade - I ran the same sway bar, but turned it around and ran it behind the rear axle. The mounts are on the chassis at the very rear of the truck and the attachment points on my bag mounts that are behind the axle. No pictures of it here on my work computer. It worked out real well for me. I'll post pictures tonight if anyones interested.
Jay 67CHEVY SWB,355, built 700r, 5/7,9",posi 3.50,REAR BAGS,HOOSIERS, A/C. 54CHEVY - BURB, beginning construction(well, i gotta take it apart first!) 36FORD PU - WAITING 38CHEVY - 2DR SD,CHASSIS FINISHED 46CHEVY - BURB - waiting |
#19 | |
#20 |
Formerly ADHDCARGUY
Here's a couple of the finished pics (after 7,000 mi). I'll clean it up real good once in the Spring, after that, quick washes and "Cruisin"! Any other questions, I'll be happy to answer. By the way, that's a "Fuelcellguy" tank that's been Linex'd. The first pic is the tank in first trial fit. The last pic is the cardboard template I took to Fuelcellguy. It shows pretty well how I mounted the sway bar in relation to the tank.
#21 | |
