Old 10-17-2002, 02:00 AM   #1
mac attack
Post Convert 3/4 ton to 1/2 ton
As I have a 3/4 ton '71 GMC and want the looks of a 1/2 ton GMC, can I just change front spindles and coils plus the rear end? I want to lower the truck 4" and use 5 lug wheels all around. The darn truck is just too high.
mac attack is offline   Reply With Quote
Old 10-17-2002, 02:36 AM   #2
Alaskan
Truck'n the alcan
Alaskan's Avatar
Welcome aboard. Try using the search. I'm sure you'll find lots of info.
68 GMC 4x4
71 C20 Custom Deluxe
83 1/2 ton conversion van
Alaskan is offline   Reply With Quote
Old 10-17-2002, 11:18 AM   #3
crazy longhorn
Fabricate till you "puke"
On the front end, you will need to use the 1/2 ton lower a arms, all 4 ball joints, & the outer tie rod ends, then the spindles will bolt on. Are you leaf or coil on the rear?
crazy longhorn is offline   Reply With Quote
