01-16-2008, 08:02 AM | #1 |
Nothing to see here.....
Corvette Rallyes and Disc Brakes??
Does anyone have this combination of wheels and brakes? I have 15", 6 lug, 10" wide 'Vette Rallyes and I am going to pick up a front disc brake kit from GMCPauls. I am wondering if I am going to have any clearance problems.
anyone know??? Has anyone used the GMCPaul's kit??? Thanks!
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
01-16-2008, 10:47 AM | #2 |
Re: Corvette Rallyes and Disc Brakes??
From what I have read on here it depends on the inside of your wheels.
There was a post last spring with a diagram showing the difference on the inside of the wheel.
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
01-16-2008, 10:54 AM | #3 |
Ask 70c10. He used the kit from GMCPauls....
1997 GMC Sierra Ext 1965 Mustang |
01-16-2008, 11:16 AM | #4 |
This is from GMCPauls site
'69 short step with dreams of being a hot rod You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. |
01-16-2008, 11:52 AM | #5 |
I ground my calipers on the out side. It gave me the clearance I needed.
01-16-2008, 11:56 AM | #6 |
Corvette Rally's disc brakes...yup!!!
Alex 1971 Lil' Red 350 SBC 700R4 |
01-16-2008, 12:28 PM | #7 |
That is the diagram I was thinking of.......
01-16-2008, 01:08 PM | #8 |
Old Skool Club
I have ECE 6-lug disc conversion on my truck, and I am running Wheel Vintique vette-style rallye wheels. On the front, I have 15x8's with a 4-inch backspace. The rears are 15x10's with a 5-inch backspace. Th9ey clear without any problems.
On the other hand, I have a '96 GMC with dropped spindles from DJM. I cannot run the stock wheels on the front, nor can I run a wheel with a 4-inch backspace, if I am running 15-inch diameter wheels. Larger diameter wheels won't be a problem. Just don't have extra funds at the moment and my tires are newly-installed on the custom wheels I already had.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
01-16-2008, 11:48 AM | #9 | |
67-72 Addict!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads Last edited by 70c10; 01-16-2008 at 11:48 AM. |
01-16-2008, 01:51 PM | #10 |
I have 15" x 10" wides all the way around with 275/60's. Didn't want the front to track wider though.......I have just enough to tuck the tires on bumps with an additional 2.5" drop. Hope it all works out.
70C10, were you happy with GMCPau'l's kit?? ChevLoRay, happy with the ECE?? Here the setup I have at this point.
01-17-2008, 03:00 PM | #11 | |
67-72 Addict!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
01-17-2008, 07:56 AM | #12 |
I'm a bit paranoid now! So a disc brake conversion is going to cause the rims to set further out???????
Remember, I have 10" wide rims with a 4" backspace.
01-17-2008, 11:00 AM | #13 | |||
Union Electrician
Yep sure will by about 3/4" on each side, GM madee up for this on the 71-2 by making the rear end 3/4" wider on each side to make the wheels track the same. You could add a spacer in the rear to even them out.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
01-17-2008, 01:08 PM | #14 |
Old Skool Club
I am quite satisfied with my ECE components. I added some NAPA stuff to the mix and have a completely rebuilt front suspension.
Yes, the change from drums to discs on these trucks will add to width of the front track. When I did mine, I was running 15x8's with too much backspace. I swapped them for a pair of 15x7's that I was running on another '69, and solved the problem of tires that came into contact with the fenders and wheel openings. By the way, are you SURE that the wheels you are running are 10-inches wide? The just don't look like they should if they are, like they have a heckuva offset to the inside. I'm running 10-inch wide wheels on the rear of my truck, with 8-inch wide wheels on the front. Rear has a 5-inch backspace. Front has a 4-inch backspace. I have had zero problems with this setup. As an aside, I have to run 15x7's on the front of my '96, with a 3.5-inch backspace, to clear the lower control arms with the inside of my wheels.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. Last edited by ChevLoRay; 01-17-2008 at 01:14 PM. |
01-17-2008, 03:45 PM | #15 |
Holy crap, I am an idiot! All of you are right! I have 15 x 8 rims. I have no clue why I thought they were 10's! I chalk this screw up to know sleep due to a 9 month old son!!!!!!!!
Okay clear the page. I have 15 x 8's with 4.5 backspacing and 275/60/15's. 70C10, byrd said that there would be a 3/4" increase in spacing. Did you see that with the GMCPaul kit? ChevLoRay, Thanks for the info. Dig your truck. I see a 'Nam decal on there. If you were there, Thank You for your service! Now I think I will write "I have 15" x 8" rims a thousand time on the chalkboard.....
01-17-2008, 05:17 PM | #16 |
67-72 Addict!
Yes. I don't know the exact amount but they are pushed out further.
