Old 01-16-2008, 12:03 PM   #1
jugernot
Life, Be In It.....
jugernot's Avatar
Cardboard Dash Tube?
Its the tube that goes inside the dash bezel for the turn signal and high beam lights. I remember seeing them for sale on one of the parts sights but I can't remember which one. Does anyone know?
THANKS FOR THE HELP......HAHAHAHA. I FOUND SOME. WWW.EARLYCLASSIC.COM HAD THEM.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 01-16-2008, 02:30 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Cardboard Dash Tube?
A long time ago I made my own out of stiff card stock. I used the old one as a model and cut them the same diameter and length. Worked pretty good.
68gmsee is offline   Reply With Quote
Old 01-16-2008, 02:38 PM   #3
70c10
67-72 Addict!
70c10's Avatar
You can use 3/4" pipe that will last forever and looks great because it's white on the inside!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 01-16-2008, 02:41 PM   #4
463
463's Avatar
Jim -70c10;You can use 3/4" pipe that will last forever and looks great because it's white on the inside. thanks 463
thats a good idea
463 is offline   Reply With Quote
Old 01-16-2008, 03:03 PM   #5
byrd
Union Electrician
byrd's Avatar
I have a blue million of these little tubes, plastic color tops and gaskets for the high beams and turn signals if anyone needs anymore.
I like to make the turn signals red and the high beam green just S&G.....Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
