01-16-2008, 12:31 PM | #1 |
2 - 6 cylinder line questions
Added some stuff this weekend
1) Where does the vacuum line on the air cleaner connect to (coiled beside snorkle in picture) - one to actuator on snorkle and the other to....??? 2)What gets connected to the large port on the riser from the carb? (would it be a line from port (just under the end of the snorkle in the picture) at the front part of the valve cover where I have a little breather now)? As always, Thanks for any input!
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
01-16-2008, 02:14 PM | #2 |
'71 chevy s.bed/s.side
Re: 2 - 6 cylinder line questions
I'll have to check on the vacuum line, but the large line on the riser goes to a hole in the valve cover on the left front. This is an old pic before I did the air cleaner swap. The older pic is from a board member some time ago, can't remember who. Hope he doesn't mind sharing it.
IMG]http://i6.photobucket.com/albums/y249/Botietruck/aircond.jpg[/IMG]
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! Last edited by Botietruck; 01-16-2008 at 02:23 PM. |
01-17-2008, 06:23 PM | #3 | |
01-17-2008, 03:29 AM | #4 |
Cool, that's what I thought on the large one. Now to figure out the little one - it goes from the snorkle module, up under the air cleaner to the temp sensor in there, off the temp sensor and back out to ?????
One question for you Botie, at the top rear of the valve cover, you have a very long hose going to the port beside the carb. Why is it so long? (the one on mine is only about 14")
01-17-2008, 06:08 AM | #5 | |
Active Member
I'll scan pic if I can get the $%^&* to work right. |
01-17-2008, 06:42 AM | #6 |
Active Member
Here's a pic...
01-17-2008, 06:49 AM | #7 |
Active Member
And here's the Haynes description of how it works.
http://www.haynes.com/files/product/13.10210sp.pdf btw. My GMC truck did not have the same setup but I believe it's because it was a 68. I've been thinking of trying to find the stock breather and convert it to the way it was. |
01-17-2008, 01:25 PM | #8 | |
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! |
01-17-2008, 01:51 PM | #9 |
Active Member
Okay, one more time. Of all places Auto Zone has the best explanation for the Thermac System. Shows where the hoses go and how they're connected. Check it out... You can click the pics to enlarge.
http://www.autozone.com/az/cds/en_us...rInfoPages.htm |
01-17-2008, 06:41 PM | #10 |
Size Matters
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News. ...WOOOO HOOOO!!!! |
01-17-2008, 07:41 AM | #11 |
Thanks 68 - that's what I have now and just like the pic, my hose is just hanging there
But now, I also see a component call a "delay valve".... wonder what year that is from.. and, nope, I don't have one
01-17-2008, 05:11 PM | #12 |
Botie - gotcha on the hose!
68gm - that link was better - it says it conects to the manifold vacuum T. Now I gotta find a T.... I think I can figure it up from there.... Thanks all!
01-18-2008, 09:05 AM | #13 |
Auggie, I found those brackets in a salvage yard. They are from a 250 engine and the compressor is a NAPA Reman for the '71 250 engine. Thanks for the comments!
01-23-2008, 08:11 AM | #14 |
Some good info for us 6 banger's! =O)
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
