Old 01-16-2008, 05:17 PM   #1
MisterE72
Keep Your Nose Clean
Can ECE and CPP suspension parts mix?
I'm lookin' at buying ECE's 4 - 6 drop (2.5 spindles..ect) and I like CPP's rear disk brake kit with crossdrilled rotors. I figure I may as well get matching rotors up front. Do the CPP rotors fit ECE spindles?
Thanks.
MisterE72 is offline   Reply With Quote
Old 01-16-2008, 07:03 PM   #2
custom72c20
custom72c20's Avatar
Re: Can ECE and CPP suspension parts mix?
I would like to know also. Hopefully others will chime in.
Nick
Old pic of my 72: http://img340.imageshack.us/my.php?image=img0435co5.jpg
04 Silverado Daily Driver
68 GMC short step http://67-72chevytrucks.com/vboard/s...d.php?t=379665
"I'll beat you to the gas station!!"
custom72c20 is offline   Reply With Quote
Old 01-16-2008, 07:19 PM   #3
stope4
This is a question you may have to ask ECE and CPP but, with that said, I would think if CPP brakes bolts to the factory mountings on the original spindles, I can't see why they wouldn't bolt to Early Classics drop spindles, and work. My factory calipers mounted to the Early Classic drop spindles as a direct bolt on. There was nothing extra to do other than to replace the spindles.
stope4 is offline   Reply With Quote
Old 01-16-2008, 08:16 PM   #4
MisterE72
I just thought I run it through you folks first since they don't open until tomorrow. Did you also replace the front brake disk? I'm wondering if I would need to buy new calipers as well if I go with anything other than the stock brake disk.
Old 01-17-2008, 06:01 AM   #5
ortegamotor
ortegamotor's Avatar
yes the parts work with each other.i used ECE drop spindels with CPP cross drilled rotors ,they go right on.the only problem you might have is with the rear disc set up that CPP makes.they use various parts to put it together . but no need to worry ECE does not offer rear disc anyway last time i checked. Tony
ortegamotor is offline   Reply With Quote
Old 01-17-2008, 01:02 PM   #6
stope4
I reused the original calipers, rotors and disks on the new spindles. I did not replace my rotors.
Old 01-17-2008, 10:52 PM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I don't see why they wouldn't fit nor work together.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
