01-17-2008, 07:52 AM | #1 |
Neutral safety switch, reopen a can of worms
This weekend I tackled the project to shorten the steering column to get the wheel out of my lap( I installed 99 Denali buckets with 3 point seatbelts and they are much larger than stock seats).
Ok, so the only problem I have is the NSS! The hole location moved to outside the firewall and the firewall mounting bracket goes right over the top of it. I looked at cutting a new hole and re-mounting the switch higher up the column inside the cab, but it looks like the tab the switch rides on is punched out of a piece of steel and stands up only inside the original hole. Currently I have the NSS screwed to a piece of metal under the dash and connected to drive the truck but want a more permanent solution. Can the switch be mounted elsewhere on the column, and how? What years van tilt column should I look for to upgrade to tilt? Thanks for all the great info guys. I'm sooo glad I found this site.
Dave in Socal 69 Chevy C10 42 BSA WM20 47 Harley WL |
01-17-2008, 08:39 AM | #2 |
Re: Neutral safety switch, reopen a can of worms
1997 GMC Sierra Ext 1965 Mustang |
01-17-2008, 10:12 AM | #3 |
Parts and more parts
Have you considered a floor shift and eliminating the column shifter and NSS?
01-17-2008, 12:43 PM | #4 |
Why not just move the NSS ala converting a van tilt to work on a truck?
http://67-72chevytrucks.com/vboard/s...threadid=63328
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI Last edited by neonlarry; 01-17-2008 at 12:43 PM. |
01-17-2008, 01:22 PM | #5 |
Awesome stuff guys!
That's exactly the info I was looking for as far as cutting the new NSS hole. Can anyone recommend what year(s) of van column to search for? Thanks again,
01-17-2008, 01:29 PM | #6 | |
Wrenchin & Sandin!!!
Randy Shorewood, IL. My Favorite eBay Searches My Driver Restore Thread 1971 C10 Longbed 2005 Silverado Shortbed 2005 FXDWG |
01-17-2008, 03:49 PM | #7 |
81 and older on the van tilts, 82 and up have ign switch on colume early ones have the correct wiring plug latter ones require a harnes adapter avalible at gm dealerships for about $12
common sense isn't so common anymore |
