86 C10
Bagged Guys did y'all have to notch cab?
im going to four link my truck and wanted to know if yall had to notch the cab for the one peice drive shaft. Pics would be great thanks.
1986 C10 2001 chevy silverado purchased 8-29-09 sold 2004 silverado purchased 8-27-10 sold ![]() |
Formerly ADHDCARGUY
Re: Bagged Guys did y'all have to notch cab?
I'm not 4 link, mines ladder bar with a 2" notch. When it is sitting on the bump stops, I've about 1 1/2' clearance between the cab and the drive shaft and my cab mounts need to be replaced which might give me another little bit! But I've a 9" and I don't know if the drive shaft might be higher in Chevy rear in relation to the axle center line.
Jay 67CHEVY SWB,355, built 700r, 5/7,9",posi 3.50,REAR BAGS,HOOSIERS, A/C. 54CHEVY - BURB, beginning construction(well, i gotta take it apart first!) 36FORD PU - WAITING 38CHEVY - 2DR SD,CHASSIS FINISHED 46CHEVY - BURB - waiting Last edited by JayG; 01-17-2008 at 02:27 PM. Reason: left out some info. |
i had to notch my cab about 2 inches.. the back part hangs down so you can cut that without cutting into the support brace under
Dino's 78 lays frame hard with NO cutting to the cab. You will have to notch the crossmember behind the cab. It's running a Dropmember and a KP six-link.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#5 | |
86 C10
86 C10
I've searched couldn't find out.
With out 73-87 4 link kit you get the new driveline crossmember notch included. None of out customers have had to notch the cab while running a one piece driveline. The Porterbuilt truck Nathan was refering to has our complete rear suspension kit installed on it, and it lays hard on 22's.
![]() On this truck, the drive line notch was welded and smoothed in. ![]() This truck has the notch simply bolted in as the kit was designed with the no fabrication . There's plenty of room between the cab and driveline.
The back of the 67-72 cabs are totally different from the 73-87 trucks. On the early trucks the frame kicks up right behind the cab, and the cab is lower on the chassis as well. The later (73-87) have those body mounts that really space the cab up over the frame, and they don't have that large pinch that hangs down either. ..... Lucky dogs .
As Clint mentioned, Dino's 78 does have a one-piece drive-shaft. The Dropmember moves the motor and trans up a bit, so we had to make our own notch for the drive-shaft in the crossmember behind the cab... to make a little more room! Still no cab cutting!
The LuvShack Garage
I Luv the look of that Blue frame, who's toy is that on?
That truck belongs to my buddy Jim Cunningham out here in Cali. We're hoping to finish it up soon and get it driving to the shows over the next few months. He recently moved and we have to get the shop back in order and start making some noise.
It'd be alot cooler if you did
I had to cut a little bit out of my floor (right after the transmission) under the seat for the drive shaft to clear. motor in stock location.
