01-18-2008, 12:19 PM | #1 |
Show Off Those Guages
Let's see some pics of your guages. From the most custom of custom to a refreshed stock set. Let's see em all. I'll start it out with my blue stock ones. The pic is extremely hard to see due to a really cruddy camera and the fact that the blue bulbs are extremely dim but i tried.
01-18-2008, 12:22 PM | #2 |
Re: Show Off Those Guages
heres mine...
01-18-2008, 12:24 PM | #3 |
TILT COLUMN GURU
Here's mine.
01-18-2008, 12:26 PM | #4 |
72 Chevelle Club
Mine
I Have The Right To Remain Silent,But Lack The Ability 1972 Chevelle ... Mine 2006 Trailblazer... Hers 2002 Buick century ... Kids 2002 K1500 Z-71 EXT CAB ... Daily Driver 2005 Rockwood Roo ... For Camping 1974 Harley-Davidson XLH Sportster 84'' stroker |
01-18-2008, 12:33 PM | #5 | |
FarmBoy.
not to hi-jack..
but Bob. how do you like the tach mounted there? and how did you mount the tach there? just curious..getting ready to put one in mine, and was trying to determind spots for it and all that. thanks! oh. and. low option stock. -Sam.
1969 GMC C1500. long fleet. 307. 3 on the tree. 3.07 gears. Oliver green. Bent and bruised. Daily Driver. Quote:
http://67-72chevytrucks.com/vboard/s...d.php?t=242993 |
01-18-2008, 12:40 PM | #6 |
72 Chevelle Club
Had to put it there otherwise the shift indicator hits it. I do like it where it is I can still see all the gauges and it's a monster tach what's not to love!!!!!
01-18-2008, 12:35 PM | #7 |
here's a daylight pic - shoulda just posted this one to begin with
04-15-2015, 01:21 PM | #8 | |
im pretty good with wiring but i have no idea what wire does what
1967custom |
04-15-2015, 08:33 PM | #9 |
Great pictures!
I have a 1969 C10 in which the previous owner mounted Auto Meter gauges. I recently had to pull out the dash and discovered a RAT'S NEST of wires! Complete mess. Every gauge works, but there's a million miles of wires. I'd like to wire the gauges to a central connector so I can pull the dash and disconnect just one wire connector. Does anyone have pictures/instructions/etc for that? Thanks in advance! |
04-15-2015, 09:09 PM | #10 |
the old. and the new with LED lighting.
01-18-2008, 12:53 PM | #11 |
Stock CST with tach
69 Chevy 4x4 383 Power |
01-18-2008, 01:05 PM | #12 |
67-72 Addict!
Here's a few I've done with carbon fiber overlays, white faces, tachs, clocks, flames, etc..
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
01-18-2008, 01:16 PM | #13 |
I have a radical idea!
White overlays in my big '69 C-30 car hauler. Nothing fancy!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
01-18-2008, 01:38 PM | #14 |
That's right, it's Copper!!
Here's mine!
01-18-2008, 02:02 PM | #15 |
01-18-2008, 02:10 PM | #16 |
01-18-2008, 09:53 PM | #17 |
Installed as soon as I figure what to put in the center
01-18-2008, 11:36 PM | #18 |
Old member
This is what I have.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
01-18-2008, 12:56 PM | #19 |
Here's mine
01-18-2008, 11:42 PM | #20 |
Here are the ones in my project truck...(the only ones I have pix of at the moment)
bottom row are Stewart Warner gauges that the PO installed... Amperes, Watts, Vacuum and Oil Pressure |
01-19-2008, 12:22 AM | #21 |
Sorry I dont have any more strait on
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
01-19-2008, 12:39 AM | #22 |
How do you get the faces of the gauges different colors? I don't get the process?
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project. 1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver. |
01-19-2008, 12:44 AM | #23 |
Here's mine. Obviusly I'm not done yet. But here's what they look like so far.
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! |
01-19-2008, 08:02 AM | #24 |
Is that phenolic?
01-19-2008, 11:56 PM | #25 |
Yes. It's 3/4" birch plywood for the structure. And skinned with phenolic. I'm going to build a phenolic glove box cover, and a phenolic bezel piece to cover up the hacked out radio hole the PO cut. I'm on the fence as to weather or not it's gettting painted. I love the look of the phenolic, but it'd be the only brown in the interior. But I've got plenty of time to figure that out while I'm workin' on the rest of the truck. BTW, good eye! Jay
