01-19-2008, 01:14 PM | #1 |
Swapping to 73-78 front grill?
I previously thought about swapping my front clip to a 83-87 front end, but have found a new love for the earlier front clips. I like my 80 front end, but nothing beats the beauty of those round headlights.
Do all the 73-78 moldings and bezels fit onto my rad support? and what are all the parts I would need? Thanks, Wes
Wes 1980 GMC Sierra SCSB-2WD 1986 Chevrolet C10 SCSB-2WD Last edited by 1980GMC; 01-19-2008 at 01:21 PM. |
01-19-2008, 01:25 PM | #2 |
Re: Swapping to 73-78 front grill?
Not sure on your question but I will say you are making the right choice. I have an 87, and love the 80's front clips but If I had a 73-80 I would DEFINETLY not swap it to 81+. The round lights were the first half of this generation truck, I would never want to "molest" it. The round lights always had a spot in my heart lol.
01-19-2008, 01:29 PM | #3 |
Are you sure I love the rectangle headlights of my 80!!!! the grill too
01-19-2008, 02:09 PM | #4 |
Happy to be here
Keep in mind there were two styles for 80. The Silverado got the single rectangle headlight, and the lower trim level got the round one.
01-19-2008, 05:00 PM | #5 |
Wishin' I had more money!
My Scottsdale has the round ones.
As far as I know, you need new headlight buckets and lights. Maybe someone else can chime in but you might need a new grille, grille trim, and other little parts as well. Last edited by xtreme80; 01-19-2008 at 05:00 PM. |
01-19-2008, 11:58 PM | #6 | |||
What about the grille moldings?
Wes 1980 GMC Sierra SCSB-2WD 1986 Chevrolet C10 SCSB-2WD |
01-20-2008, 12:36 AM | #7 | |
Happy to be here
You might trying looking on LMC's website. I don't always recommend them for parts, but they have the greatest exploded views and parts lists available.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 01-20-2008 at 12:36 AM. |
01-20-2008, 01:16 AM | #8 |
Hello,
I have personally always thought that the 73-80 Chevy trucks were the coolest design in the history of these trucks. Do you plan to swap the grille itself, or just to the round headlamps? If you do swap the grille and decide to go with a 77-80 grille, it should swap right in. The 73-76 grille requires the removal of a few vertical supports to fit into the radiator support. LMC shows the same P/N for the core support from 73 up to 80 (I know all of this already because I plan to install a 73-75 grille into my K30 project (using a '79 support) . The early grille is deeper and will not fit with the vertical members in place (luckily, as easy as everything else on these trucks is to work with, they are only bolted to the core support). As far as swapping only to the round headlamps (reusing the same grille), you should only need the headlight buckets and chrome bezels. Long story short, you can make your truck look exactly like any style from 73 up to 80 using the same radiator support. Good luck in your swap. Joe |
01-20-2008, 01:45 AM | #9 |
yeller
Are the lower valances the same, where the front signals reside? I thought they were different too.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
01-20-2008, 01:59 AM | #10 | |
I believe you're correct. I forgot to mention that in my previous post. Luckily, that's just a bolt-on panel as well. So as it stands, Wes would need the headlamp buckets, bezels, turn signal assemblies and lower valance panel to do this right. Thanks for the correction, Joe |
01-20-2008, 02:56 AM | #11 |
www.73-87chevytrucks.com
Difference is the Lower valence, headlight bezels, buckets and lower grill trim (79/80 YE9 got the full chrome piece)
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
01-20-2008, 06:33 AM | #12 | |
Thanks to everyone for all the great help. Wes
