01-21-2008, 01:43 PM | #1 |
its all about the +6 inches
lets talk about C-notches
How much do they cost?
Where would I find a good quality piece at a good price? Any disadvantages? (dies this weaken the frame much?) Can they be reasonably installed on a vehicle that has the body on it? |
01-21-2008, 01:54 PM | #2 |
Re: lets talk about C-notches
I bought mine from CPP for $120 shipped. It's a bolt in piece, but we welded it on. I don't know of any disadvantages to it. We took the bed off to do it. It could have been done with the bed on, but having it off made it a lot easier.
72 C10 lwb fleetside -stock 350/350 combo |
01-21-2008, 02:34 PM | #3 |
Im not a fan of the bolt on notches, you do lose strength with them. Its not as bad with a coil spring truck since the weight of the truck is mainly suported before the notch. I boxed my frame and bent notch pices and welded it all up. and as a general rule you dont want the notch to be deeper than half the frame heigth. I realize the majority of people dont have the tools to do it that way but i wouldent feel all that safe with bolt in notches, especially if i used the truck to tow.
01-21-2008, 11:52 PM | #4 |
The Older Generation
My '70 GMC shortbed frame has pieces of 3 1/2 or 4", 3/16 wall tubing cut in half and welded in. Looks pretty strong to me. I don't think I would have a problem using it that way.... I guess it would depend on how much clearance a guy needed. Here is a FAQ thread by Rokcrln: http://67-72chevytrucks.com/vboard/s...ighlight=notch LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-22-2008 at 12:03 AM. |
01-22-2008, 12:13 AM | #5 |
sounds like sombody's got some wheels turning. i'm gonna make my own when the time comes
common sense isn't so common anymore |
01-22-2008, 10:35 AM | #6 |
am i smelling a droped burb here?
01-22-2008, 10:53 AM | #7 |
Official Site Guitar Shredder
there is no problem with bolt in notches most are... what i did on mine and some others are ..after i got it all bolted in and snugged real tight..i welded it all the way around..shane gave me that idea..i have done probably 7-8 since i did mine... most are on daily drivers...now even with that said, you could go in and box the notch... i dont see where it will hurt anything. but it is not needed...i have done them on leafs and trailing arm type suspensions ...
01-22-2008, 11:51 AM | #8 |
Just do it like N2TRUX has on his. 6" tube cut in half & welded in. Plate the sides & you are set...
01-22-2008, 12:16 PM | #9 |
I can melt metal and make it stick, but I wouldn't even think of doing it to my frame. My welding looks like a 5 year old on crack did it.
I'm just looking at options |
01-22-2008, 03:51 PM | #10 |
Keep Your Nose Clean
I also used the CPP bolt on c-notch. It was a fairly easy install. We cut the frame with a cutting wheel and and my buddy Kris welded it.
01-23-2008, 06:27 AM | #11 |
Prestige Worldwide
I also went with the CPP notch........Same deal for me, I used the plasma to cut the frame then bolted it in like they say to, then welded it all the way around and boxed the inside for extra strength so mine is bolted and welded.... once welded the bolts are kind of useless but they do add some strength.
01-23-2008, 07:33 AM | #12 |
Tot Roddin'
I'd say CPP is the way to go.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
01-23-2008, 07:54 AM | #13 |
Fabricate till you "puke"
I dont know how far you are planning to drop there Andy? Take a look @ my longhorn http://community.webshots.com/user/hotrodhorn Im not running any notch, & figure around 5 1/2 " of drop. This only gives about 2 1/2" tween the frame & axle(fine for cruising empty), but would need air over leaf, for added capacity hauling/towing.... crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
01-23-2008, 08:23 AM | #14 |
actually Al, I'm talkin about the burb.
I have a set of 6 inch drop coils... not sure if I just need to try and trade for some 5 inch drop coils... or sell these and buy a set of 5 inch coils... or go with the C notch |
01-23-2008, 08:28 AM | #15 |
WTB this ad
Notch it!!!
01-23-2008, 09:53 AM | #16 |
I guess that a lot depends on how you plan to use the truck? For 1 I plan to load/tow with, I would tend to go conservative on the drop.....if its just a cruizer/toy, I like em low crazyL
01-23-2008, 09:29 AM | #17 |
someday it will be done!
I went with a home built one similar to N2TRUX's as well.It definitely can be done with the body on,it'll just be a bit uncomfortable is all.
I'd bet that with all you contribute to the board,you'd have no trouble finding a fellow member with welding skills in your area that'd jump at the chance to help you out with a fabbed notch.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
01-23-2008, 09:57 AM | #18 |
drop it and notch it~!
01-23-2008, 10:09 AM | #19 |
Active Member
I also used the 6" pipe cut in half and boxed it in. And it only cost me 35 bucks!
01-23-2008, 10:21 AM | #20 | |
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
01-23-2008, 10:51 AM | #21 |
Heres a post I started last winter about making a c notch. N2TRUX posted pics of his along with a couple others...
http://67-72chevytrucks.com/vboard/s...ighlight=notch |
01-23-2008, 11:24 AM | #22 |
Saving 1 truck at a time!
Floors are highly overrated...go big or go home...10" baby
BTW...cross brace and box.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) Last edited by stllookn; 01-23-2008 at 11:26 AM. |
