01-23-2008, 12:41 PM | #1 |
Its always something!
3/4 ton question
Are the 73 & newer lower 3/4 ton a-frames the same as the 67-72 3/4 ton lower a-frames.
79 p10 stepvan 72 Short Fleetside 72 Suburban 67 GMC One Ton Flatbed 64 Short Fleetside 57 Chevy 2DR Hard Top 57 Chevy 2dr wagon 65 f*** short fleet 63 C 60 Flatbed Member of the patina club |
01-24-2008, 12:20 AM | #2 |
Re: 3/4 ton question
I think the only differance is the ball joint. The hole is either bigger or smaller. It might be the upper that is different. Are you looking to do a swap?
If you have a 68 or newer you can swap everything and leave the crossmember in. Then use the drum brake hoses and the mount on the back of the crossmember. |
01-24-2008, 01:00 AM | #3 |
I am using the 88-98 light duty 3/4 ton spindles on my 69 panel. One of the mods is I have to use a 3/4 ton lower a-frame so I can use the 88-98 ball joint. I already have a 77 3/4 ton that I can rob them from.
01-24-2008, 09:30 AM | #4 |
i know the lca bushings are different but don't know if they are interchangable
common sense isn't so common anymore |
