Old 01-24-2008, 09:34 AM   #1
samwise68
FarmBoy.
samwise68's Avatar
Starter Issues when Cold?
hey all.
the truck finally made it on the road. today, my dad drove it to work, with no hitches. aside from one littl thing.
when it's cold, the starter just *click*'s. like, it won't engage the drive, or something. he wiggled the cables, and it started.
so, could it be a bad connections at the starter? or is the starter shot...?
your opinions would be greatly appreciated.
thanks in advance all.
-Sam.
1969 GMC C1500. long fleet.
307. 3 on the tree. 3.07 gears.
Oliver green. Bent and bruised. Daily Driver.
Screw patina... it's a beater...Beaters are cool.
my build thread - Project Homebrew:
http://67-72chevytrucks.com/vboard/s...d.php?t=242993
samwise68 is offline   Reply With Quote
Old 01-24-2008, 09:36 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Starter Issues when Cold?
if he wiggled the cables, and got it to start... I'd start with tightening the cables.
Old 01-24-2008, 09:43 AM   #3
El Jay
Gone to greener pastures
I'd pull the cables & clean them, & the battery terminals before snugging them down.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 01-24-2008, 10:01 AM   #4
samwise68
FarmBoy.
samwise68's Avatar
alright, total misunderstanding on my behalf, from my Dad.
the cables wouldn't wiggle. (sorry, i just caught something about cables).
all the starter would do is *click*, and he finally got it to engage and turn the engine over.
he said something about there being two washers in the starter...that might not be doing their job...? idk.
i hope that clears some things up, since it's not the wires. heh.
-Sam.
Old 01-24-2008, 10:12 AM   #5
89 crew
Is it one fast click? or fast repeated clicks?
89 crew is offline   Reply With Quote
Old 01-24-2008, 11:03 AM   #6
samwise68
FarmBoy.
samwise68's Avatar
just one click at a time, per key turn.
i'm thinking it's something in the solenoid...?
-Sam.
Old 01-24-2008, 11:37 AM   #7
Bob 68327
72 Chevelle Club
Bob 68327's Avatar
I would say start with the sol. and while you have the starter out try hooking a battery to it and shorting the bat. term . to the start term . and see if the starter works . You could also take it with you to the parts store and have them test it. My 2Cents , Bob
I Have The Right To Remain Silent,But Lack The Ability
1972 Chevelle ... Mine
2006 Trailblazer... Hers
2002 Buick century ... Kids
2002 K1500 Z-71 EXT CAB ... Daily Driver
2005 Rockwood Roo ... For Camping
1974 Harley-Davidson XLH Sportster 84'' stroker
Bob 68327 is offline   Reply With Quote
Old 01-24-2008, 12:06 PM   #8
89 crew
The one click at a time means it is getting enough power to engage the solenoid. but it can't turn the engine. I would guess the solenoid is good and the rest of the starter is the problem. Could be a dead place in the armature, or excessive wear. I would recommend just replace the starter.
Old 01-24-2008, 01:08 PM   #9
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Cold increases resistance to current flow so it may be something as simple as the cranking amps of the battery. I would say that 600 cca or less might be the cause especially if the battery is older. There are too many other things that might cause the problem also. The two large terminals inside the solenoid are what sends power to the starter windings and armature. They are connected by a copper washer inside the solenoid and if there is arcing on the washer it would cause high resistance and a poor contact to the starter. I have included a picture of how all this works. If the battery is ok and all the connections are good then I agree with 89 crew that a new starter is the best option. VV
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 01-24-2008, 07:14 PM   #10
heavy70
heavy70's Avatar
Just bypass the solenoid on the starter and put a ford solenoid on the inner fender!
heavy70 is offline   Reply With Quote
Old 01-25-2008, 12:59 AM   #11
crzngmychvy
"1972 C5"
crzngmychvy's Avatar
My 59 used to do that and this was my solution. In my case it would happen when the starter got too hot.
When I was out on the road and had trouble starting it I would have a person hit the ignition while I hit the starter with a rock/pipe/some hard object. If I timed it right it worked every time.
- 72 2wd Blazer ...sold...
2wd Blazer Page
crzngmychvy is offline   Reply With Quote
Old 01-25-2008, 01:38 AM   #12
89 crew
Originally Posted by VetteVet View Post
Cold increases resistance to current flow so it may be something as simple as the cranking amps of the battery. I would say that 600 cca or less might be the cause especially if the battery is older. VV
I thought about the battery but most of the time if it is that bad it won't start after it is warm either.
If the washer had that much resistance it would pop in and out instead of locking in and not turning.
great pic showing how it works.
