Restoration Virgin!
Dash issue HELP..Send Photos
Hello,
I bought my truck from a guy trying (and I mean TRYING) to make wood dash bezel, glove box and center dash out of wood, BUT unfortunately I didn't like it and am in the process of trying to figure out what I will do for the center dash area (where the ignition, heater control, air vent, etc is located). It was completely cut out...could you guys send some photos of what you did in the center section of the dash OR make suggestions. ![]() I was thinking of having someone fabricate a piece that I could fasten back in there (I would make a template of an original). Thanks!!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
Re: Dash issue HELP..Send Photos
It would be easier and probably faster to just replace the complete dash, then you can go air or non air. And there has been several for sale here in the parts section.
You can cut out the old dash and put in another one...it's spot welded in, and if you're gonna keep the truck, that's what I'd do.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
It's a catastrophic success.
![]() Join Date: Jan 2003
Without having to pull the windshield to get to the spot welds. Another option is to cut the dash under the pad and then weld in a new front
thats a good idea, never thought of that.
1947 International KB-1 1957 Chevy Bel-Air riding low 1962 swb fleetside 2002 Chevrolet Silverado 7-inch lift on 35 Daily driver 2016 Chevy Tahoe Better halves ride |
![]() That might be a little more in-depth than you were looking forward too. But it should be a relatively easy project since the dash pad will hide any imperfections that might be left behind. It sounds like your truck might have been a donor at one time? Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! ![]() |
