Old 01-28-2008, 11:13 AM   #1
my70chevyc10
my70chevyc10's Avatar
Converting to automatic from 3 speed help
What all do i need to install a turbo 350 in my truck here is what i allready have or am going to get.
1) Trans (HAVE)
2) Trans cooler from work (KRAGENS)
3) Trans cooler lines from work (KRAGENS)
4) flexplate from work (KRAGENS)
5) Torque converter (HAVE)
6) Hurst pistol grip shifter (HAVE)
7) trans cross member (THE TRUCK SHOP)
"Your trucks fast! You must have been going 120 when I passed you."
"Owning A 10 Sec Import Is Like Coming Out Of The Closet, In The End Ur Still Gay"
If for some reason i loose to a import...At least i can go home knowing the vehicle i drive drops girls panties...
my70chevyc10 is offline   Reply With Quote
Old 01-28-2008, 11:28 AM   #2
HavinSomeFun
Still Just Havin Some Fun!
HavinSomeFun's Avatar
Re: Converting to automatic from 3 speed help
Shifter, Yoke for the drive shaft, correct lenght drive shaft.
a green one with some stuff done to it....
HavinSomeFun is offline   Reply With Quote
Old 01-28-2008, 11:34 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
If you use a "short tail shaft" 350 turbo transmission, the driveshaft you have will work. The 3 speed yoke will also work in the turbo 350.
Keith
Convert to disc brakes.
Old 01-28-2008, 11:43 AM   #4
72BLUZ
72BLUZ's Avatar
you will need a column, and the linkage from the column to the tranny. i got mine from uncle. well i got the linkage from uncle
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream.
It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan
72BLUZ is offline   Reply With Quote
Old 01-28-2008, 11:47 AM   #5
1966gmc
Why does it taste purple?
1966gmc's Avatar
Not always.My 3 spd had a 10 spline yoke and I had to buy a 27 spline yoke.Just need to install it
No need for a column if he is converting to floor shifter
1966gmc is offline   Reply With Quote
Old 01-28-2008, 11:49 AM   #6
jkaylor68gmc
jkaylor68gmc's Avatar
he said he had a floor shifter. He can just cap over the column shifter. Sounds like you have it covered. Is the starter the same? just wondering.
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 01-31-2008, 03:49 AM   #7
chris71
chris71's Avatar
the starter is different. 3 speed the starter bolts to the bell housing, th350 the starter bolts to the engine block. dont forget trans mount, dipstick tube, kickdown cable, fluid, and converter to flexplate bolts. good luck.
'55 3100 2nd series short-bed stepside
'70 Corvette coupe stingray
'71 Chevelle 2-dr coupe SS clone
'71 C10 long-bed fleetside
'83 long-haired brunette wife
chris71 is offline   Reply With Quote
