Old 01-29-2008, 11:36 AM   #1
skokie
skokie's Avatar
Need help with tilt column
Today I was out working on installing my tilt column I had a issue with the column to firewall seal. It was installed backyards. Without taking the column apart from the bottom end I could not find a way to fix it. I tried reversing it but it kept flipping back over. Stubborn piece of rubber So I just said hell with it I will cut it, flip it and then it should pop right on. EEEEEEEEHHHHHHHHH wrong move.
After I cut it the rubber was kinda shredded. In short I need a new one and have one on order but here is the $64000 question. How do I install it?
Do I need to remove the bottom end of the column to install? Area circled in red in pic.
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 01-29-2008, 11:49 AM   #2
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Re: Need help with tilt column
If I were you I would take it back to where you got it. You are going to have to completely disassemble the column to remove the shift tube this should be done by an experienced tech.
KevsClassics is offline   Reply With Quote
Old 01-29-2008, 11:55 AM   #3
skokie
skokie's Avatar
The only thing in my way is the linkage connector on the column. Could you stop at that point? Or by taking that clip off mean that everything is coming out?
68 build thread
Old 01-29-2008, 12:08 PM   #4
uncle
I think it's about impossible to do without cutting the rubber or taking the column apart.
uncle is offline   Reply With Quote
Old 01-29-2008, 12:12 PM   #5
skokie
skokie's Avatar
Anyone have the tilt column breakdown diagram? Did a search but came up empty.
68 build thread
Old 01-29-2008, 12:34 PM   #6
Hart_Rod
Hart_Rod's Avatar
Here you go:
http://67-72chevytrucks.com/vboard/s...d.php?t=157328
Hart_Rod is offline   Reply With Quote
Old 01-29-2008, 01:53 PM   #7
skokie
skokie's Avatar
Thanks Rob.
68 build thread
Old 01-29-2008, 09:09 PM   #8
70GMCer
70GMCer's Avatar
This is what I did and didn't have to take the column apart. Some may not agree with this, but tough, it worked for me. I removed the lower clip that holds the bearing in place. I then "Bent" the shifter arm to a point where the rubber seal fits over it. I then straightened the shifter arm back out and re-installed the bearing clip. I didn't have to cut the seal. I've did a few columns like this and have never had an issue with the shifter arm breaking. That arm is thick steel, and would have to take a lot of bending back and forth to break. If you don't want to do this, then take the column apart.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 01-30-2008, 02:57 AM   #9
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
You can do it without disassembly, I have done it several times it will stretch over the arm!!
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 01-30-2008, 06:51 AM   #10
neonlarry
neonlarry's Avatar
Bending the shift arm is the way I have always gotten them on or off.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 01-30-2008, 07:39 AM   #11
CJJ67
I bent the arm thing when I did mine. Didn't break so I guess it was o.k. to do it that way.
CJJ67 is offline   Reply With Quote
Old 01-30-2008, 09:53 AM   #12
uncle
Yes, this can be done. I JUST HAD A MAJOR BRAINFART when you asked. That's why this board is so helpful.
